Datasheet Intersil ISL84514 — Даташит
Производитель | Intersil |
Серия | ISL84514 |
Low-Voltage, Single Supply, SPST, Analog Switches
Купить ISL84514 на РадиоЛоцман.Цены — от 39 до 93 ₽ 27 предложений от 21 поставщиков Микросхема: LOW-VOLTAGE, SINGLE SUPPLY, SPST | |||
ISL84514IBZ-T | от 39 ₽ | ||
ISL84514IH-T Intersil | 45 ₽ | ||
ISL84514IBZ Intersil | по запросу |
ISL84514IB | ISL84514IB-T | ISL84514IBZ | ISL84514IBZ-T | ISL84514IH-T | ISL84514IHZ-T | |
N | 1 | 2 | 3 | 4 | 5 | 6 |
Корпус | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld SOIC | 8 Ld SOIC T+R | 5 Ld SOT T+R | 5 Ld SOT T+R |
Parameters / Models | ISL84514IB | ISL84514IB-T | ISL84514IBZ | ISL84514IBZ-T | ISL84514IH-T | ISL84514IHZ-T |
Количество каналов | 1 | 1 | 1 | 1 | 1 | 1 |
Chg Inj | 8 pC | 8 pC | 8 pC | 8 pC | 8 pC | 8 pC |
Configuration | NO | NO | NO | NO | NO | NO |
Description | Low-Voltage, Single Supply, SPST, Analog Switches | Low-Voltage, Single Supply, SPST, Analog Switches | Low-Voltage, Single Supply, SPST, Analog Switches | Low-Voltage, Single Supply, SPST, Analog Switches | Low-Voltage, Single Supply, SPST, Analog Switches | Low-Voltage, Single Supply, SPST, Analog Switches |
Drain Cap | 30 pF | 30 pF | 30 pF | 30 pF | 30 pF | 30 pF |
IS | 2 μA | 2 μA | 2 μA | 2 μA | 2 μA | 2 μA |
Leakage | 4 nA | 4 nA | 4 nA | 4 nA | 4 nA | 4 nA |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Peak Temp | 240°C | 240°C | 260°C | 260°C | 240°C | 260°C |
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard |
Source Cap | 14 pF | 14 pF | 14 pF | 14 pF | 14 pF | 14 pF |
Switch or MUX | Switch | Switch | Switch | Switch | Switch | Switch |
TOFF | 100 ns | 100 ns | 100 ns | 100 ns | 100 ns | 100 ns |
TON | 150 ns | 150 ns | 150 ns | 150 ns | 150 ns | 150 ns |
Type of Switch | SPST | SPST | SPST | SPST | SPST | SPST |
VCC (Single) (max) | 12 V | 12 V | 12 V | 12 V | 12 V | 12 V |
VCC (Single) (min) | 2.4 V | 2.4 V | 2.4 V | 2.4 V | 2.4 V | 2.4 V |
rDS(ON) | 10 Ω | 10 Ω | 10 О© | 10 О© | 10 Ω | 10 О© |
Серия: ISL84514 (6)
- Switches, MUX & Crosspoints > Medium Voltage > Switches/MUXs/Crosspoints
