Datasheet Linear Technology LTC3128 — Даташит
Серия | LTC3128 |
3A Monolithic Buck-Boost Supercapacitor Charger and Balancer with Accurate Input Current Limit
LTC3128 - 3A Monolithic Buck-Boost Supercapacitor Charger and Balancer with Accurate Input Current Limit
PDF, 520 Кб, Версия: F
Купить LTC3128 на РадиоЛоцман.Цены — от 343 до 1 710 ₽ 25 предложений от 13 поставщиков Buck-Boost Switching Regulator IC Positive Adjustable 1.8V 1 Output 3A 20-WFQFN Exposed Pad | |||
LTC3128EUFD#PBF Analog Devices | 343 ₽ | ||
LTC3128EUFD#TRPBF Linear Technology | 453 ₽ | ||
LTC3128EUFD Linear Technology | от 464 ₽ | ||
LTC3128IFE#TRPBF Analog Devices | от 945 ₽ |
LTC3128EFE#PBF | LTC3128EFE#TRPBF | LTC3128EUFD#PBF | LTC3128EUFD#TRPBF | LTC3128IFE#PBF | LTC3128IFE#TRPBF | LTC3128IUFD#PBF | LTC3128IUFD#TRPBF | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 |
Корпус | TSSOP-24 | TSSOP-24 | 4x5 QFN-20 | 4x5 QFN-20 | TSSOP-24 | TSSOP-24 | 4x5 QFN-20 | 4x5 QFN-20 |
Код корпуса | FE | FE | UFD | UFD | FE | FE | UFD | UFD |
Parameters / Models | LTC3128EFE#PBF | LTC3128EFE#TRPBF | LTC3128EUFD#PBF | LTC3128EUFD#TRPBF | LTC3128IFE#PBF | LTC3128IFE#TRPBF | LTC3128IUFD#PBF | LTC3128IUFD#TRPBF |
Demo Boards | DC1887A | DC1887A | DC1887A | DC1887A | DC1887A | DC1887A | DC1887A | DC1887A |
Design Tools | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model |
Экспортный контроль, yes/no | нет | нет | нет | нет | нет | нет | нет | нет |
Основные особенности | Programmable Current Limit, Burst Mode, Active Charge Balancing, Output Disconnect, Power Good | Programmable Current Limit, Burst Mode, Active Charge Balancing, Output Disconnect, Power Good | Programmable Current Limit, Burst Mode, Active Charge Balancing, Output Disconnect, Power Good | Programmable Current Limit, Burst Mode, Active Charge Balancing, Output Disconnect, Power Good | Programmable Current Limit, Burst Mode, Active Charge Balancing, Output Disconnect, Power Good | Programmable Current Limit, Burst Mode, Active Charge Balancing, Output Disconnect, Power Good | Programmable Current Limit, Burst Mode, Active Charge Balancing, Output Disconnect, Power Good | Programmable Current Limit, Burst Mode, Active Charge Balancing, Output Disconnect, Power Good |
Ishutdown, мкА | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Isupply, мА | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 |
Рабочий диапазон температур, °C | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Выходной ток, A | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 |
Supercaps In Series | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Topology | Buck-Boost | Buck-Boost | Buck-Boost | Buck-Boost | Buck-Boost | Buck-Boost | Buck-Boost | Buck-Boost |
Vin Max, В | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
Vin Min, В | 1.73 | 1.73 | 1.73 | 1.73 | 1.73 | 1.73 | 1.73 | 1.73 |
Vout Max, В | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
Vout Maximum | 5.5V | 5.5V | 5.5V | 5.5V | 5.5V | 5.5V | 5.5V | 5.5V |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: LTC3128 (8)
- Power Management > Supercapacitor Chargers
