Datasheet Songle Relay SRD-09VDC-FD-A — Даташит
Производитель | Songle Relay |
Серия | SRD (T73) |
Модель | SRD-09VDC-FD-A |
Реле для бытовых электроприборов
Datasheet SRD
PDF, 3.7 Мб, Файл закачен: 21 фев 2018, Страниц: 2
Subminature High Power Relay 7A/10A/15A
Купить SRD-09VDC на РадиоЛоцман.Цены — от 36 до 64 ₽ Управляющее напряжение 9 Вольт. Подключаемая нагрузка до 10 Ампер, 30 Вольт DC, 250 Вольт AC. Может использоваться в различных проектах, где... | |||
SRD-09VDC-SL-C | 36 ₽ | ||
Реле Songle SRD-09VDC-SL-C электромеханическое (9V, 10A) | 39 ₽ | ||
Реле T73 09V 10A (SRD-09VDC-SL-C) | 64 ₽ | ||
SRD-09VDC-SL-A Songle Relay | по запросу |
Размеры | 19.2×15.5×15.2 мм |
Номинальное рабочее напряжение | 9 В |
Серия: SRD (T73) (96)
- SRD-05VDC-FD-A SRD-05VDC-FD-B SRD-05VDC-FD-C SRD-05VDC-FL-A SRD-05VDC-FL-B SRD-05VDC-FL-C SRD-05VDC-SD-A SRD-05VDC-SD-B SRD-05VDC-SD-C SRD-05VDC-SL-A SRD-05VDC-SL-B SRD-05VDC-SL-C SRD-06VDC-FD-A SRD-06VDC-FD-B SRD-06VDC-FD-C SRD-06VDC-FL-A SRD-06VDC-FL-B SRD-06VDC-FL-C SRD-06VDC-SD-A SRD-06VDC-SD-B SRD-06VDC-SD-C SRD-06VDC-SL-A SRD-06VDC-SL-B SRD-06VDC-SL-C SRD-09VDC-FD-A SRD-09VDC-FD-B SRD-09VDC-FD-C SRD-09VDC-FL-A SRD-09VDC-FL-B SRD-09VDC-FL-C SRD-09VDC-SD-A SRD-09VDC-SD-B SRD-09VDC-SD-C SRD-09VDC-SL-A SRD-09VDC-SL-B SRD-09VDC-SL-C SRD-12VDC-FD-A SRD-12VDC-FD-B SRD-12VDC-FD-C SRD-12VDC-FL-A SRD-12VDC-FL-B SRD-12VDC-FL-C SRD-12VDC-SD-A SRD-12VDC-SD-B SRD-12VDC-SD-C SRD-12VDC-SL-A SRD-12VDC-SL-B SRD-12VDC-SL-C SRD-18VDC-FD-A SRD-18VDC-FD-B SRD-18VDC-FD-C SRD-18VDC-FL-A SRD-18VDC-FL-B SRD-18VDC-FL-C SRD-18VDC-SD-A SRD-18VDC-SD-B SRD-18VDC-SD-C SRD-18VDC-SL-A SRD-18VDC-SL-B SRD-18VDC-SL-C SRD-24VDC-FD-A SRD-24VDC-FD-B SRD-24VDC-FD-C SRD-24VDC-FL-A SRD-24VDC-FL-B SRD-24VDC-FL-C SRD-24VDC-SD-A SRD-24VDC-SD-B SRD-24VDC-SD-C SRD-24VDC-SL-A SRD-24VDC-SL-B SRD-24VDC-SL-C SRD-36VDC-FD-A SRD-36VDC-FD-B SRD-36VDC-FD-C SRD-36VDC-FL-A SRD-36VDC-FL-B SRD-36VDC-FL-C SRD-36VDC-SD-A SRD-36VDC-SD-B SRD-36VDC-SD-C SRD-36VDC-SL-A SRD-36VDC-SL-B SRD-36VDC-SL-C SRD-48VDC-FD-A SRD-48VDC-FD-B SRD-48VDC-FD-C SRD-48VDC-FL-A SRD-48VDC-FL-B SRD-48VDC-FL-C SRD-48VDC-SD-A SRD-48VDC-SD-B SRD-48VDC-SD-C SRD-48VDC-SL-A SRD-48VDC-SL-B SRD-48VDC-SL-C
- Household appliance relay
SRD09VDCFDA, SRD 09VDC FD A
