Datasheet Songle Relay SRD-05VDC-SL-C — Даташит
Производитель | Songle Relay |
Серия | SRD (T73) |
Модель | SRD-05VDC-SL-C |
Реле для бытовых электроприборов
Datasheet SRD
PDF, 3.7 Мб, Файл закачен: 21 фев 2018, Страниц: 2
Subminature High Power Relay 7A/10A/15A
Купить SRD-05VDC-SL-C на РадиоЛоцман.Цены — от 12 до 2 440 ₽ 18 предложений от 12 поставщиков Одна группа контактов на переключение. Управляющее напряжение: 5 VDC. На фото представлено 6-ти вольтовое реле, которое по массагабаритам аналогично 5-ти вольтовому,... | |||
SRD-05VDC-SL-C Hongfa | 12 ₽ | ||
Реле SRD-05VDC-SL-C SRD-09VDC-SL-C SRD-12VDC-SL-C SRD-24VDC-SL-C 5V 9V 12V 24V 10A 250VAC 5PIN T73 | 19 ₽ | ||
Реле Songle SRD-05VDC-SL-C электромеханическое (5V, 10A) | 39 ₽ | ||
SRD-05VDC-SL-C | по запросу |
Размеры | 19.2×15.5×15.2 мм |
Номинальное рабочее напряжение | 5 В |
Серия: SRD (T73) (96)
- SRD-05VDC-FD-A SRD-05VDC-FD-B SRD-05VDC-FD-C SRD-05VDC-FL-A SRD-05VDC-FL-B SRD-05VDC-FL-C SRD-05VDC-SD-A SRD-05VDC-SD-B SRD-05VDC-SD-C SRD-05VDC-SL-A SRD-05VDC-SL-B SRD-05VDC-SL-C SRD-06VDC-FD-A SRD-06VDC-FD-B SRD-06VDC-FD-C SRD-06VDC-FL-A SRD-06VDC-FL-B SRD-06VDC-FL-C SRD-06VDC-SD-A SRD-06VDC-SD-B SRD-06VDC-SD-C SRD-06VDC-SL-A SRD-06VDC-SL-B SRD-06VDC-SL-C SRD-09VDC-FD-A SRD-09VDC-FD-B SRD-09VDC-FD-C SRD-09VDC-FL-A SRD-09VDC-FL-B SRD-09VDC-FL-C SRD-09VDC-SD-A SRD-09VDC-SD-B SRD-09VDC-SD-C SRD-09VDC-SL-A SRD-09VDC-SL-B SRD-09VDC-SL-C SRD-12VDC-FD-A SRD-12VDC-FD-B SRD-12VDC-FD-C SRD-12VDC-FL-A SRD-12VDC-FL-B SRD-12VDC-FL-C SRD-12VDC-SD-A SRD-12VDC-SD-B SRD-12VDC-SD-C SRD-12VDC-SL-A SRD-12VDC-SL-B SRD-12VDC-SL-C SRD-18VDC-FD-A SRD-18VDC-FD-B SRD-18VDC-FD-C SRD-18VDC-FL-A SRD-18VDC-FL-B SRD-18VDC-FL-C SRD-18VDC-SD-A SRD-18VDC-SD-B SRD-18VDC-SD-C SRD-18VDC-SL-A SRD-18VDC-SL-B SRD-18VDC-SL-C SRD-24VDC-FD-A SRD-24VDC-FD-B SRD-24VDC-FD-C SRD-24VDC-FL-A SRD-24VDC-FL-B SRD-24VDC-FL-C SRD-24VDC-SD-A SRD-24VDC-SD-B SRD-24VDC-SD-C SRD-24VDC-SL-A SRD-24VDC-SL-B SRD-24VDC-SL-C SRD-36VDC-FD-A SRD-36VDC-FD-B SRD-36VDC-FD-C SRD-36VDC-FL-A SRD-36VDC-FL-B SRD-36VDC-FL-C SRD-36VDC-SD-A SRD-36VDC-SD-B SRD-36VDC-SD-C SRD-36VDC-SL-A SRD-36VDC-SL-B SRD-36VDC-SL-C SRD-48VDC-FD-A SRD-48VDC-FD-B SRD-48VDC-FD-C SRD-48VDC-FL-A SRD-48VDC-FL-B SRD-48VDC-FL-C SRD-48VDC-SD-A SRD-48VDC-SD-B SRD-48VDC-SD-C SRD-48VDC-SL-A SRD-48VDC-SL-B SRD-48VDC-SL-C
- Household appliance relay
SRD05VDCSLC, SRD 05VDC SL C
