Datasheet Songle Relay SRD-12VDC-SL-C — Даташит
Производитель | Songle Relay |
Серия | SRD (T73) |
Модель | SRD-12VDC-SL-C |
Реле для бытовых электроприборов
Datasheet SRD
PDF, 3.7 Мб, Файл закачен: 21 фев 2018, Страниц: 2
Subminature High Power Relay 7A/10A/15A
Купить SRD-12VDC-SL-C на РадиоЛоцман.Цены — от 19 до 2 351 ₽ 19 предложений от 13 поставщиков Управляющее напряжение 12 Вольт. Подключаемая нагрузка до 10 Ампер, 250 Вольт AC. Может использоваться в различных проектах на Arduino, где требуется... | |||
Реле SRD-05VDC-SL-C SRD-09VDC-SL-C SRD-12VDC-SL-C SRD-24VDC-SL-C 5V 9V 12V 24V 10A 250VAC 5PIN T73 | 19 ₽ | ||
SRD-12VDC-SL-C Songle Relay | 30 ₽ | ||
SRD-12VDC-SL-C Songle Relay | 48 ₽ | ||
SRD-12VDC-SLC | по запросу |
Размеры | 19.2×15.5×15.2 мм |
Номинальное рабочее напряжение | 12 В |
Серия: SRD (T73) (96)
- SRD-05VDC-FD-A SRD-05VDC-FD-B SRD-05VDC-FD-C SRD-05VDC-FL-A SRD-05VDC-FL-B SRD-05VDC-FL-C SRD-05VDC-SD-A SRD-05VDC-SD-B SRD-05VDC-SD-C SRD-05VDC-SL-A SRD-05VDC-SL-B SRD-05VDC-SL-C SRD-06VDC-FD-A SRD-06VDC-FD-B SRD-06VDC-FD-C SRD-06VDC-FL-A SRD-06VDC-FL-B SRD-06VDC-FL-C SRD-06VDC-SD-A SRD-06VDC-SD-B SRD-06VDC-SD-C SRD-06VDC-SL-A SRD-06VDC-SL-B SRD-06VDC-SL-C SRD-09VDC-FD-A SRD-09VDC-FD-B SRD-09VDC-FD-C SRD-09VDC-FL-A SRD-09VDC-FL-B SRD-09VDC-FL-C SRD-09VDC-SD-A SRD-09VDC-SD-B SRD-09VDC-SD-C SRD-09VDC-SL-A SRD-09VDC-SL-B SRD-09VDC-SL-C SRD-12VDC-FD-A SRD-12VDC-FD-B SRD-12VDC-FD-C SRD-12VDC-FL-A SRD-12VDC-FL-B SRD-12VDC-FL-C SRD-12VDC-SD-A SRD-12VDC-SD-B SRD-12VDC-SD-C SRD-12VDC-SL-A SRD-12VDC-SL-B SRD-12VDC-SL-C SRD-18VDC-FD-A SRD-18VDC-FD-B SRD-18VDC-FD-C SRD-18VDC-FL-A SRD-18VDC-FL-B SRD-18VDC-FL-C SRD-18VDC-SD-A SRD-18VDC-SD-B SRD-18VDC-SD-C SRD-18VDC-SL-A SRD-18VDC-SL-B SRD-18VDC-SL-C SRD-24VDC-FD-A SRD-24VDC-FD-B SRD-24VDC-FD-C SRD-24VDC-FL-A SRD-24VDC-FL-B SRD-24VDC-FL-C SRD-24VDC-SD-A SRD-24VDC-SD-B SRD-24VDC-SD-C SRD-24VDC-SL-A SRD-24VDC-SL-B SRD-24VDC-SL-C SRD-36VDC-FD-A SRD-36VDC-FD-B SRD-36VDC-FD-C SRD-36VDC-FL-A SRD-36VDC-FL-B SRD-36VDC-FL-C SRD-36VDC-SD-A SRD-36VDC-SD-B SRD-36VDC-SD-C SRD-36VDC-SL-A SRD-36VDC-SL-B SRD-36VDC-SL-C SRD-48VDC-FD-A SRD-48VDC-FD-B SRD-48VDC-FD-C SRD-48VDC-FL-A SRD-48VDC-FL-B SRD-48VDC-FL-C SRD-48VDC-SD-A SRD-48VDC-SD-B SRD-48VDC-SD-C SRD-48VDC-SL-A SRD-48VDC-SL-B SRD-48VDC-SL-C
- Household appliance relay
SRD12VDCSLC, SRD 12VDC SL C
