Datasheet Microchip ATMEGA3208 — Даташит
Производитель | Microchip |
Серия | ATMEGA3208 |
The ATmega3208 is a microcontroller featuring the 8-bit AVR® processor with hardware multiplier - running at up to 20MHz and with up to 32 KB Flash, 4 KB SRAM and 256 bytes of EEPROM in 28- and 32-pin packages
ATmega3208/4808 - 28-pin Data Sheet
PDF, 1.2 Мб, Файл опубликован: 26 фев 2018
ATmega3208/4808 - 32-pin Data Sheet
PDF, 1.5 Мб, Файл опубликован: 26 фев 2018
Manual megaAVR 0-series - ATmega3208/3209/4808/4809 microcontrollers
PDF, 2.9 Мб, Файл опубликован: 26 фев 2018, Страниц: 483
Manual contains the general descriptions of the peripherals
Купить ATMEGA3208 на РадиоЛоцман.Цены — от 85 до 8 130 ₽ 17 предложений от 11 поставщиков AVR megaAVR® 0, Functional Safety (FuSa) Microcontroller IC 8-Bit 20MHz 32KB (16K x 16) FLASH 32-VFQFN (5x5) | |||
ATMEGA3208-XU Microchip | 85 ₽ | ||
ATMEGA3208-XU Microchip | 86 ₽ | ||
ATMEGA3208-XU Microchip | 161 ₽ | ||
ATMEGA3208-AFR Microchip | от 349 ₽ |
ATMEGA3208-AFR | ATMEGA3208-MFR | |
N | 1 | 2 |
Корпус | TQFP | VQFN |
Parameters / Models | ATMEGA3208-AFR | ATMEGA3208-MFR |
ADC Input | 12 | 12 |
ADC with Computation | No | No |
Angular Timer | No | No |
Архитектура | 8 | 8 |
CPU Type | 8-bit AVR | 8-bit AVR |
CRC | Yes | Yes |
Class B Hardware | Yes | Yes |
Configurable Logic Cell, CLC/CCL | 1 | 1 |
Emulated EEPROM in Flash | 256 / HEF | 256 / HEF |
High Voltage Capable | No | No |
I2C | 1 | 1 |
Internal Oscillator | 20 MHz, 32 kHz | 20 MHz, 32 kHz |
Internal Voltage Reference, Bandgap | Yes | Yes |
Lead Count | 32 | 32 |
Math Accelerator | No | No |
Max 16-Bit Digital Timers | 4 | 4 |
Max ADC Resolution, Bits | 10 | 10 |
Max CPU Speed, МГц | 20 | 20 |
Max PWM outputs, including complementary | 9 | 9 |
Количество компараторов | 1 | 1 |
Operation Voltage Max, В | 5.5 | 5.5 |
Operation Voltage Min, В | 1.8 | 1.8 |
Package Width | 7x7x1mm | 5x5x0.9mm |
Peripheral Pin Select / Pin Muxing | Yes | Yes |
Pin count | 32 | 32 |
Размер памяти программ, KB | 32 | 32 |
SPI | 1 | 1 |
SRAM, Bytes | 4096 | 4096 |
Temp Range Max | 125 | 125 |
Temp Range Min | -40 | -40 |
UART | 3 | 3 |
Zero Cross detect | No | No |
ATMEGA3209 ATMEGA4808 ATMEGA4809
Серия: ATMEGA3208 (2)
- Microcontrollers > 8-bit Microcontrollers
