Datasheet Microchip ATMEGA3209 — Даташит
Производитель | Microchip |
Серия | ATMEGA3209 |
The ATmega3209 is a microcontroller featuring the 8-bit AVR® processor with hardware multiplier - running at up to 20MHz and with up to 32 KB Flash, 4 KB SRAM and 256 bytes of EEPROM in 48-pin packages
Datasheet ATmega3209, ATmega4809 - 48-pin
PDF, 792 Кб, Файл опубликован: 26 фев 2018, Страниц: 68
megaAVR 0-series
megaAVR 0-series
Manual megaAVR 0-series - ATmega3208/3209/4808/4809 microcontrollers
PDF, 2.9 Мб, Файл опубликован: 26 фев 2018, Страниц: 483
Manual contains the general descriptions of the peripherals
Купить ATMEGA3209 на РадиоЛоцман.Цены — от 93 до 10 769 ₽ 22 предложений от 12 поставщиков AVR megaAVR® 0, Functional Safety (FuSa) Microcontroller IC 8-Bit 20MHz 32KB (16K x 16) FLASH 48-TQFP (7x7) | |||
ATMEGA3209-AFR Microchip | 93 ₽ | ||
ATMEGA3209-AFR Microchip | 94 ₽ | ||
ATMEGA3209-AFR Microchip | 229 ₽ | ||
ATMEGA3209-AFR Atmel | по запросу |
ATMEGA3209-AFR | ATMEGA3209-MFR | |
N | 1 | 2 |
Корпус | TQFP | UQFN |
Parameters / Models | ATMEGA3209-AFR | ATMEGA3209-MFR |
ADC Input | 16 | 16 |
ADC with Computation | No | No |
Angular Timer | No | No |
Архитектура | 8 | 8 |
CPU Type | 8-bit AVR | 8-bit AVR |
CRC | Yes | Yes |
Class B Hardware | Yes | Yes |
Configurable Logic Cell, CLC/CCL | 1 | 1 |
Emulated EEPROM in Flash | 256 / HEF | 256 / HEF |
High Voltage Capable | No | No |
I2C | 1 | 1 |
Internal Oscillator | 20 MHz, 32 kHz | 20 MHz, 32 kHz |
Internal Voltage Reference, Bandgap | Yes | Yes |
Lead Count | 48 | 48 |
Math Accelerator | No | No |
Max 16-Bit Digital Timers | 5 | 5 |
Max ADC Resolution, Bits | 10 | 10 |
Max CPU Speed, МГц | 20 | 20 |
Max PWM outputs, including complementary | 8 | 8 |
Количество компараторов | 1 | 1 |
Operation Voltage Max, В | 5.5 | 5.5 |
Operation Voltage Min, В | 1.8 | 1.8 |
Package Width | 7x7x1mm | 6x6x0.5mm |
Peripheral Pin Select / Pin Muxing | Yes | Yes |
Pin count | 48 | 48 |
Размер памяти программ, KB | 32 | 32 |
SPI | 1 | 1 |
SRAM, Bytes | 4096 | 4096 |
Temp Range Max | 125 | 125 |
Temp Range Min | -40 | -40 |
UART | 4 | 4 |
Zero Cross detect | No | No |
ATMEGA3208 ATMEGA4808 ATMEGA4809
Серия: ATMEGA3209 (2)
- Microcontrollers > 8-bit Microcontrollers
