Datasheet Microchip ATMEGA4808 — Даташит
Производитель | Microchip |
Серия | ATMEGA4808 |
The ATmega4808 is a microcontroller featuring the 8-bit AVR® processor with hardware multiplier - running at up to 20MHz and with up to 48 KB Flash, 6 KB SRAM and 256 bytes of EEPROM in 28- and 32-pin packages
ATmega3208/4808 - 28-pin Data Sheet
PDF, 1.2 Мб, Файл опубликован: 26 фев 2018
ATmega3208/4808 - 32-pin Data Sheet
PDF, 1.5 Мб, Файл опубликован: 26 фев 2018
Manual megaAVR 0-series - ATmega3208/3209/4808/4809 microcontrollers
PDF, 2.9 Мб, Файл опубликован: 26 фев 2018, Страниц: 483
Manual contains the general descriptions of the peripherals
Купить ATMEGA4808 на РадиоЛоцман.Цены — от 33 до 8 783 ₽ 39 предложений от 15 поставщиков 8 Bit MCU, AVR Family ATmega4808 Series Microcontrollers, 20 МГц, 48 КБ, 6 КБ, 32 вывод(-ов), QFN | |||
ATMEGA4808-AFR Microchip | 33 ₽ | ||
ATMEGA4808-MU Microchip | 229 ₽ | ||
ATMEGA4808XU | 8 783 ₽ |
ATMEGA4808-AFR | ATMEGA4808-MFR | |
N | 1 | 2 |
Корпус | TQFP | VQFN |
Parameters / Models | ATMEGA4808-AFR | ATMEGA4808-MFR |
ADC Input | 12 | 12 |
ADC with Computation | No | No |
Angular Timer | No | No |
Архитектура | 8 | 8 |
CPU Type | 8-bit AVR | 8-bit AVR |
CRC | Yes | Yes |
Class B Hardware | Yes | Yes |
Configurable Logic Cell, CLC/CCL | 1 | 1 |
Emulated EEPROM in Flash | 256 / HEF | 256 / HEF |
High Voltage Capable | No | No |
I2C | 1 | 1 |
Internal Oscillator | 20 MHz, 32 kHz | 20 MHz, 32 kHz |
Internal Voltage Reference, Bandgap | Yes | Yes |
Lead Count | 32 | 32 |
Math Accelerator | No | No |
Max 16-Bit Digital Timers | 4 | 4 |
Max ADC Resolution, Bits | 10 | 10 |
Max CPU Speed, МГц | 20 | 20 |
Max PWM outputs, including complementary | 9 | 9 |
Количество компараторов | 1 | 1 |
Operation Voltage Max, В | 5.5 | 5.5 |
Operation Voltage Min, В | 1.8 | 1.8 |
Package Width | 7x7x1mm | 5x5x0.9mm |
Peripheral Pin Select / Pin Muxing | Yes | Yes |
Pin count | 32 | 32 |
Размер памяти программ, KB | 48 | 48 |
SPI | 1 | 1 |
SRAM, Bytes | 6144 | 6144 |
Temp Range Max | 125 | 125 |
Temp Range Min | -40 | -40 |
UART | 3 | 3 |
Zero Cross detect | No | No |
ATMEGA3208 ATMEGA3209 ATMEGA4809
Серия: ATMEGA4808 (2)
- Microcontrollers > 8-bit Microcontrollers
