Datasheet Microchip ATTINY3217 — Даташит
Производитель | Microchip |
Серия | ATTINY3217 |
The ATtiny3217 of microcontroller featuring the 8-bit AVR® processor with hardware multiplier - running at up to 20MHz and with up to 32 KB Flash, 2 KB SRAM and 256 bytes of EEPROM in a 24-pin package
ATtiny3217/ATtiny1617 Data Sheet
PDF, 4.5 Мб, Файл опубликован: 21 июн 2018
Купить ATTINY3217 на РадиоЛоцман.Цены — от 59 до 12 763 ₽ 15 предложений от 11 поставщиков AVR tinyAVRTM1, Functional Safety (FuSa) Microcontroller IC 8-Bit 16MHz 32KB (32K x 8) FLASH 24-VQFN (4x4) | |||
ATtiny3217-MFR Microchip | 59 ₽ | ||
ATTINY3217-MF Microchip | 88 ₽ | ||
ATTINY3217-MN Microchip | 112 ₽ | ||
ATTINY3217-MFR Microchip | по запросу |
ATTINY3217-MFR | ATTINY3217-MNR | |
N | 1 | 2 |
Корпус | VQFN | VQFN |
Parameters / Models | ATTINY3217-MFR | ATTINY3217-MNR |
ADC Input | 20 | 20 |
ADC with Computation | No | No |
Angular Timer | No | No |
Архитектура | 8 | 8 |
CPU Type | 8-bit AVR | 8-bit AVR |
CRC | Yes | Yes |
Class B Hardware | Yes | Yes |
Configurable Logic Cell, CLC/CCL | 1 | 1 |
Emulated EEPROM in Flash | 256 / HEF | 256 / HEF |
Hardware Touch Peripheral | PTC | PTC |
High Voltage Capable | No | No |
I2C | 1 | 1 |
Internal Oscillator | 20 MHz, 32 kHz | 20 MHz, 32 kHz |
Internal Voltage Reference, Bandgap | Yes | Yes |
Lead Count | 24 | 24 |
Math Accelerator | No | No |
Max 16-Bit Digital Timers | 3 | 3 |
Max 8-Bit Digital Timers | 1 | 1 |
Max ADC Resolution, Bits | 10 | 10 |
Max CPU Speed, МГц | 20 | 20 |
Max DAC Resolution, Bits | 8 | 8 |
Max PWM outputs, including complementary | 8 | 8 |
Количество компараторов | 3 | 3 |
Number of DACs | 3 | 3 |
Operation Voltage Max, В | 5.5 | 5.5 |
Operation Voltage Min, В | 1.8 | 1.8 |
Package Width | 4x4x0.9mm | 4x4x0.9mm |
Peripheral Pin Select / Pin Muxing | Yes | Yes |
Pin count | 24 | 24 |
Размер памяти программ, KB | 32 | 32 |
SPI | 1 | 1 |
SRAM, Bytes | 2048 | 2048 |
Temp Range Max | 125 | 125 |
Temp Range Min | -40 | -40 |
UART | 1 | 1 |
Zero Cross detect | No | No |
Серия: ATTINY3217 (2)
- Microcontrollers > 8-bit Microcontrollers
