Datasheet Texas Instruments HPA01070PWPR — Даташит
Серия | TPA3110D2 |
Модель | HPA01070PWPR |
15W Filter-Free Class D Stereo Amplifier with SpeakerGuard (TPA3110) 28-HTSSOP -40 to 85
TPA3110D2 15-W Fil ter-Free Stereo Class-D Audio Power Amplifier With Speakerguardв„ў datasheet
PDF, 1.9 Мб, Версия: F, Файл опубликован: 25 апр 2017
Audio Amplifiers Order MFG part # TPA3110D2PWPR | |||
HPA01070PWPR Texas Instruments | 94 ₽ | ||
HPA01070PWPR Texas Instruments | по запросу | ||
Pin | 28 |
Package Type | PWP |
Industry STD Term | HTSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | TPA3110D2 |
Width (мм) | 4.4 |
Length (мм) | 9.7 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Analog Supply (V) | 26 Min |
Audio Input Type | Analog |
Closed/Open Loop | Closed |
Control Interface | Hardware |
Package Group | HTSSOP |
Package Size: mm2:W x L | 28HTSSOP: 62 mm2: 6.4 x 9.7(HTSSOP) PKG |
Power Stage Supply(Max) | 26 В |
Power Stage Supply(Min) | 8 В |
Power to Bridge Tied Load(Max) | 15 W |
Rating | Catalog |
Speaker Channels | 2 Max |
Supported Bridge Tied Load(Min) | 4 Ohms |
- Evaluation Modules & Boards: TPA3110D2EVM
TPA3110D2 Evaluation Module
- AN-1737 Managing EMI in Class D Audio Applications (Rev. A)PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit. - Using Thermal Calculation Tools for Analog ComponentsPDF, 1.1 Мб, Файл опубликован: 2 сен 2010
This document provides general guidance on the use of toolsand calculations for thermal estimates of component operating temperatures for analog devices. Of particularfocus are components with direct thermal paths to the PCB which is common for components which need a low thermal resistance to manage the dissipated power. This document provides practical considerations for estimation of o - AN-1849 An Audio Amplifier Power Supply Design (Rev. B)PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs. - Guidelines for Measuring Audio Power Amplifier PerformancePDF, 765 Кб, Файл опубликован: 30 окт 2001
This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TPA3110D2 (3)
- HPA01070PWPR TPA3110D2PWP TPA3110D2PWPR
- Semiconductors > Audio > Mid-Power Audio Amplifiers (10-50W) > Analog Input Amplifiers
