Datasheet Texas Instruments LP8860LQVFPRQ1 — Даташит
Серия | LP8860-Q1 |
Модель | LP8860LQVFPRQ1 |
Automotive Low-EMI High-Performance 4-Channel LED Driver 32-HLQFP -40 to 125
LP8860-Q1 Low-EMI Automotive LED Driver With Four 150-mA Channels datasheet
PDF, 1.7 Мб, Версия: F, Файл опубликован: 6 июл 2017
Купить LP8860LQVFPRQ1 на РадиоЛоцман.Цены — от 280 до 917 ₽ 15 предложений от 8 поставщиков LED Driver IC 4 Output DC DC Controller Step-Up (Boost) PWM Dimming 150mA 32-HLQFP (7x7) | |||
LP8860LQVFPRQ1 Texas Instruments | 280 ₽ | ||
LP8860LQVFPRQ1 Texas Instruments | 286 ₽ | ||
LP8860LQVFPRQ1 Texas Instruments | от 917 ₽ | ||
LP8860LQVFPRQ1 Texas Instruments | по запросу |
Pin | 32 |
Package Type | VFP |
Industry STD Term | HLQFP |
JEDEC Code | S-PQFP-G |
Package QTY | 1000 |
Carrier | LARGE T&R |
Маркировка | LP8860LQ1 |
Width (мм) | 7 |
Length (мм) | 7 |
Thickness (мм) | 1.4 |
Pitch (мм) | .8 |
Max Height (мм) | 1.6 |
Mechanical Data | Скачать |
Applications | Backlight,Dome,Foot Well |
Количество каналов | 4 |
Iout(Max) | 0.6 A |
Iq(Typ) | 2.5 мА |
LED Current Per Channel | 150 мА |
Package Group | HLQFP |
Package Size: mm2:W x L | 32HLQFP: 81 mm2: 9 x 9(HLQFP) PKG |
Rating | Automotive |
Special Features | Adjustable Switch Frequency,Boost Sync,Fault Diagnostic,Hybrid Dimming/Phase Shift,I2C Control,Spread Spectrum |
Switching Frequency(Max) | 2200 kHz |
Switching Frequency(Min) | 100 kHz |
Topology | Boost Controller |
Vin(Max) | 48 В |
Vin(Min) | 3 В |
Vout(Max) | 48 В |
Vout(Min) | 2 В |
- Evaluation Modules & Boards: LP8860-Q1EVM
LP8860-Q1 Evaluation Module
- Selecting the Correct LP8860-Q1 EEPROM Version (Rev. C)PDF, 287 Кб, Версия: C, Файл опубликован: 18 авг 2017
- LP8860-Q1 Boost Compensation RegistersPDF, 73 Кб, Файл опубликован: 1 сен 2017
The LP8860-Q1 device is an automotive LED driver with boost converter to support infotainment display,automotive cluster, and lighting applications. In order to support a wide range of application conditions forautomotive, LP8860-Q1 offers various settings for boost compensation with EEPROM registers. Thisdocument provides additional details for several device EEPROM registers, expanding on - PCB Layout Guideline for Automotive LED DriversPDF, 2.7 Мб, Файл опубликован: 7 апр 2017
Серия: LP8860-Q1 (10)
- Semiconductors > Power Management > LED Driver > Automotive LED Driver
