Datasheet Texas Instruments SN74LVC1G80QDCKTQ1 — Даташит
Серия | SN74LVC1G80-Q1 |
Модель | SN74LVC1G80QDCKTQ1 |
Automotive Single Positive-Edge-Triggered D-Type Flip-Flop 5-SC70 -40 to 125
SN74LVC1G80-Q1 Single Positive-Edge-Triggered D-Type Flip-Flop datasheet
PDF, 875 Кб, Файл опубликован: 7 апр 2017
Купить SN74LVC1G80QDCKTQ1 на РадиоЛоцман.Цены — от 8.71 до 102 ₽ 18 предложений от 10 поставщиков IC: цифровая; D триггер; Ch: 1; CMOS; SMD; SC70; катушка,лента; 74LVC | |||
SN74LVC1G80QDCKTQ1 Texas Instruments | 8.71 ₽ | ||
SN74LVC1G80QDCKTQ1 Texas Instruments | 36 ₽ | ||
SN74LVC1G80QDCKTQ1 Texas Instruments | от 102 ₽ | ||
SN74LVC1G80QDCKTQ1 Texas Instruments | по запросу |
Pin | 5 |
Package Type | DCK |
Industry STD Term | SOT-SC70 |
JEDEC Code | R-PDSO-G |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | 17U |
Width (мм) | 1.25 |
Length (мм) | 2 |
Thickness (мм) | .9 |
Pitch (мм) | .65 |
Max Height (мм) | 1.1 |
Mechanical Data | Скачать |
3-State Output | No |
Bits | 1 |
F @ Nom Voltage(Max) | 150 Mhz |
Gate Type | FLIP-FLOP |
ICC @ Nom Voltage(Max) | 0.01 мА |
Logic | True |
Output Drive (IOL/IOH)(Max) | 32/-32 мА |
Package Group | SC70 |
Package Size: mm2:W x L | 5SC70: 4 mm2: 2.1 x 2(SC70) PKG |
Rating | Automotive |
Schmitt Trigger | No |
Special Features | Ioff, Down translation to Vcc, Low Power |
Sub-Family | D-Type Flip-Flop |
Technology Family | LVC |
VCC(Max) | 5.5 В |
VCC(Min) | 1.65 В |
tpd @ Nom Voltage(Max) | 9.1 6 4.2 3.8 нс |
- LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC1G80-Q1 (2)
- SN74LVC1G80QDCKRQ1 SN74LVC1G80QDCKTQ1
- Semiconductors > Logic > Little Logic
