Datasheet Texas Instruments THVD1550DGKR — Даташит
Серия | THVD1550 |
Модель | THVD1550DGKR |
5V RS-485 Transceivers With В±18kV IEC ESD Protection 8-VSSOP -40 to 125
THVD15xx 5-V RS-485 Transceivers With В±18-kV IEC ESD Protection datasheet
PDF, 1.4 Мб, Файл опубликован: 12 сен 2017
Купить THVD1550DGKR на РадиоЛоцман.Цены — от 77 до 7 533 ₽ 20 предложений от 9 поставщиков IC: interface; transceiver; half duplex,RS422 / RS485; 50000kbps | |||
THVD1550DGKR Texas Instruments | 77 ₽ | ||
THVD1550DGKR Texas Instruments | 81 ₽ | ||
THVD1550DGKR Texas Instruments | 83 ₽ | ||
THVD1550DGKR Texas Instruments | от 445 ₽ |
Статус продукта | Анонсирован (Компонент анонсирован, но еще не запущен в серийное производство. Образцы могут быть как доступны, так и нет) |
Pin | 8 |
Package Type | DGK |
Industry STD Term | VSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | .97 |
Pitch (мм) | .65 |
Max Height (мм) | 1.07 |
Mechanical Data | Скачать |
Common Mode Range | -15 to 15 |
Duplex | Half |
Fail Safe | idle,open,short |
Fault Protection | -18 to 18 В |
HBM ESD | 30 kV |
ICC(Max) | 1 мА |
IEC 61000-4-2 Contact | 18 +/- kV |
No. of RX | 1 |
No. of TX | 1 |
Number of Nodes | 256 |
Package Group | VSSOP |
Rating | Catalog |
Signaling Rate(Max) | 50 Mbps |
Supply Voltage(s)(Nom) | 5 В |
RoHS | See ti.com |
- Signal Integrity vs. Transmission Rate and Cable Length for RS-485 TransceiversPDF, 1.3 Мб, Файл опубликован: 29 авг 2017
This application note contains lab data on the signal integrity of the THVD1550 RS-485 transceiver device at various cable lengths and data rates. Jitter measurements were gathered with the results tabulated and plotted.
Серия: THVD1550 (4)
- THVD1550D THVD1550DGK THVD1550DGKR THVD1550DR
- Semiconductors > Interface > RS-485/RS-422
