Datasheet Texas Instruments THVD1550DR — Даташит
Серия | THVD1550 |
Модель | THVD1550DR |
5V RS-485 Transceivers With В±18kV IEC ESD Protection 8-SOIC -40 to 125
THVD15xx 5-V RS-485 Transceivers With В±18-kV IEC ESD Protection datasheet
PDF, 1.4 Мб, Файл опубликован: 12 сен 2017
Купить THVD1550DR на РадиоЛоцман.Цены — от 32 до 5 750 ₽ 21 предложений от 10 поставщиков IC: interface; transceiver; full duplex,RS485; 400kbps; SOIC8 | |||
THVD1550DR Texas Instruments | от 32 ₽ | ||
THVD1550DR Texas Instruments | 55 ₽ | ||
SN65HVD71DR Texas Instruments | от 524 ₽ | ||
THVD1550DR Texas Instruments | по запросу |
Pin | 8 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | VD1550 |
Width (мм) | 3.91 |
Length (мм) | 4.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Common Mode Range | -15 to 15 |
Duplex | Half |
Fail Safe | idle,open,short |
Fault Protection | -18 to 18 В |
HBM ESD | 30 kV |
ICC(Max) | 1 мА |
IEC 61000-4-2 Contact | 18 +/- kV |
No. of RX | 1 |
No. of TX | 1 |
Number of Nodes | 256 |
Package Group | SOIC |
Rating | Catalog |
Signaling Rate(Max) | 50 Mbps |
Supply Voltage(s)(Nom) | 5 В |
- Signal Integrity vs. Transmission Rate and Cable Length for RS-485 TransceiversPDF, 1.3 Мб, Файл опубликован: 29 авг 2017
This application note contains lab data on the signal integrity of the THVD1550 RS-485 transceiver device at various cable lengths and data rates. Jitter measurements were gathered with the results tabulated and plotted.
Серия: THVD1550 (4)
- THVD1550D THVD1550DGK THVD1550DGKR THVD1550DR
- Semiconductors > Interface > RS-485/RS-422
