Datasheet Texas Instruments TPS2044BDRG4 — Даташит
Серия | TPS2044B |
Модель | TPS2044BDRG4 |
Quad Current-Limited Power Distribution Switches 16-SOIC -40 to 85
TPS20xxB Current-Limited, Power-Distribution Switches datasheet
PDF, 2.0 Мб, Версия: M, Файл опубликован: 19 июн 2016
Купить TPS2044BDRG4 на РадиоЛоцман.Цены — от 90 до 570 ₽ 17 предложений от 13 поставщиков USB Power SW USB Power Switch Quad 5.5V 0.75A to 1.25A 16Pin SOIC T/R | |||
TPS2044BDRG4 Texas Instruments | 90 ₽ | ||
TPS2044BDRG4 Texas Instruments | 111 ₽ | ||
TPS2044BDRG4 Texas Instruments | 117 ₽ | ||
TPS2044BDRG4 Texas Instruments | по запросу |
Pin | 16 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | 2044B |
Width (мм) | 3.91 |
Length (мм) | 9.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Continuous Current(Max) | 0.5 A |
Current Limit Topology | Constant-Current |
Enable | Active Low |
Number of Switches | 4 |
Package Group | SOIC |
Package Size: mm2:W x L | 16SOIC: 59 mm2: 6 x 9.9(SOIC) PKG |
Rating | Catalog |
USB Switch rDS(on) | 70 mOhms |
Vin(Max) | 5.5 В |
Vin(Min) | 2.7 В |
- Evaluation Modules & Boards: TPS2044BEVM-295
TPS2044B Evaluation Module
- A Power-Distribution Switch With Latched Over-Current Protection (Rev. A)PDF, 99 Кб, Версия: A, Файл опубликован: 3 июл 2007
Power-distribution switches, like the TPS203x, operate in retry mode in an overload, but some applications require the switch to latch off. The latch-off function can be implemented using the simple circuit described in this application report.
Серия: TPS2044B (4)
- TPS2044BD TPS2044BDG4 TPS2044BDR TPS2044BDRG4
- Semiconductors > Power Management > USB Power and Charging Port Controllers > Fixed Current Limited Switch
