Datasheet Texas Instruments TPS2320IPWRG4 — Даташит
Серия | TPS2320 |
Модель | TPS2320IPWRG4 |
![Datasheet Texas Instruments TPS2320IPWRG4](http://www.ti.com/graphics/folders/partimages/TPS2320.jpg)
3-13V Dual Hot-Swap IC w/ Independent Channel Circuit Breaking, Act-Low Enable 16-TSSOP -40 to 85
Dual Hot-Swap Power Controllers with Independent Circuit Breaker datasheet
PDF, 553 Кб, Версия: F, Файл опубликован: 10 май 2013
![]() 15 предложений от 12 поставщиков Hot Swap Controller 2 Channel General Purpose 16-TSSOP | |||
TPS2320IPWRG4 Texas Instruments | 106 ₽ | ||
TPS2320IPWRG4 Texas Instruments | 161 ₽ | ||
TPS2320IPWRG4 | по запросу | ||
TPS2320IPWRG4 Texas Instruments | по запросу |
Pin | 16 |
Package Type | PW |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | PD2320I |
Width (мм) | 4.4 |
Length (мм) | 5 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Channel(s) Controlled | 2 |
Current Limit Accuracy | Adjustable |
Current Limit Function Enabled | Always |
Current Limit Threshold(Typ) | Adjustable Ext FET=mV |
Current Measurement Accuracy | N/A % |
Design Support | Calculation Tool,EVM |
Fault Response | Latch Off |
ON_OFF Control Input | EN/ s |
Package Group | TSSOP |
Package Size: mm2:W x L | 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG |
Rating | Catalog |
Status Output | FLT/ |
Vabsmax_cont | 15 В |
Vin(Max) | 13 В |
Vin(Min) | 3 В |
- Evaluation Modules & Boards: TPS2301EVM-153
TPS23XX Hot Swap Power Controllers Evaluation Module
Статус продукта: В производстве (Рекомендуется для новых разработок) - Evaluation Modules & Boards: TPS2330EVM-184
TPS2330 48-V Telecom Hot Swap Evaluation Module and Interface Card
- Low Voltage (0V-5.5V) Hot-Swap Application Using TPS2300/2301PDF, 141 Кб, Файл опубликован: 1 ноя 2001
This application note illustrates the use of the TPS2300/2301 for low voltage applications. The TPS2300/2301/2310/2311/2320/2321 are dual-channel hot-swap controllers that eliminate high-frequency hot-plug or hot-removal transients, reduce inrush current, and provide overcurrent protection. The TPS2300/2301/2310/2311/2320/2321 can be easily configured for low voltage applications and are capable o - +48V/-48V Hot-Swap Applications with TPS23xx Hot-Swap ControllersPDF, 79 Кб, Файл опубликован: 24 апр 2001
The rapid development of telecommunication and networked systems has accelerated the growth of products requiring the hot-plug capability demanded by systems with a continuous uninterrupted power-on requirement. There are many hot-swap or hot-plug power management solutions available in the market today; however, the trick is picking the one that best suits the application's needs. Many applicatio - Step-By-Step Design Approach of TPS2300/01/10/11/20/21/30/31 Hotswap ControllersPDF, 169 Кб, Файл опубликован: 23 май 2003
The TPS2300/01/10/11/20/21/30/31 hotswap controllers allow safe board insertion and removal from a live backplane. With the current-limit-setting resistor (RSET), the current limit can be set much more easily than other hotswap controllers. This report uses a simple step-by-step design approach to select the essential components and parameters for typical hotswap applications. By following the des - Power Management Solutions for Infiniband (SM) I/O ModulesPDF, 75 Кб, Файл опубликован: 20 окт 2000
InfiniBand, a scalable, modular, channel-based, switched-fabric architecture, is defined for the connection of servers with servers and with storage and networking devices. Because appropriate power management is essential for quality implementations, this report presents straightforward solutions for both high-power and low-power applications as required by the InfiniBand specification.
Серия: TPS2320 (8)
- TPS2320ID TPS2320IDG4 TPS2320IDR TPS2320IDRG4 TPS2320IPW TPS2320IPWG4 TPS2320IPWR TPS2320IPWRG4
- Semiconductors > Power Management > Protection, Monitoring and Hot Swap > Hot Swap Controllers (Positive, -48V)
