Datasheet Texas Instruments TPS3305-25DGNG4 — Даташит
Серия | TPS3305 |
Модель | TPS3305-25DGNG4 |
Dual Processor Supervisory Circuit with Watchdog Timer 8-MSOP-PowerPAD -40 to 85
Dual Processor Supervisors datasheet
PDF, 990 Кб, Версия: C, Файл опубликован: 27 мар 2008
Купить TPS3305-25DGNG4 на РадиоЛоцман.Цены — от 68 до 207 ₽ 11 предложений от 8 поставщиков new in stock for immediate delivery | |||
TPS3305-25DGNG4 Texas Instruments | от 68 ₽ | ||
TPS3305-25DGNG4 Texas Instruments | 101 ₽ | ||
TPS3305-25DGNG4 Texas Instruments | по запросу | ||
Pin | 8 |
Package Type | DGN |
Industry STD Term | HVSSOP |
JEDEC Code | S-PDSO-G |
Package QTY | 80 |
Carrier | TUBE |
Маркировка | AAN |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | 1.02 |
Pitch (мм) | .65 |
Max Height (мм) | 1.1 |
Mechanical Data | Скачать |
# of Supplies Monitored | 2 |
Iq(Typ) | 40 uA |
Monitored Voltage 1 (typ)(Nom) | 1.8,2.5,3.3,5 В |
Monitored Voltage 2 (typ)(Nom) | N/A В |
Output Driver Type / Reset Output | Active-high,Active-low,Push-pull |
Package Group | MSOP-PowerPAD |
Package Size: mm2:W x L | 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) PKG |
Rating | Catalog |
Reset Threshold Accuracy | 2.4 % |
Special Features | Active Low Enable,Manual Reset,Watchdog Timer |
Threshold Voltage 1(Typ) | 1.68,2.25,2.93,4.55 В |
Threshold Voltage 2 (typ)(Typ) | N/A В |
Time Delay | 200 ms |
VCC(Max) | 6 В |
VCC(Min) | 2.7 В |
Watchdog Timer WDI | 1.6 sec |
Серия: TPS3305 (24)
- TPS3305-18D TPS3305-18DG4 TPS3305-18DGN TPS3305-18DGNG4 TPS3305-18DGNR TPS3305-18DGNRG4 TPS3305-18DR TPS3305-18DRG4 TPS3305-25D TPS3305-25DG4 TPS3305-25DGN TPS3305-25DGNG4 TPS3305-25DGNR TPS3305-25DGNRG4 TPS3305-25DR TPS3305-25DRG4 TPS3305-33D TPS3305-33DG4 TPS3305-33DGN TPS3305-33DGNG4 TPS3305-33DGNR TPS3305-33DGNRG4 TPS3305-33DR TPS3305-33DRG4
- Semiconductors > Power Management > Supervisor and Reset IC
TPS330525DGNG4, TPS3305 25DGNG4
