Datasheet Texas Instruments TPS3305-25DR — Даташит
Серия | TPS3305 |
Модель | TPS3305-25DR |
Dual Processor Supervisory Circuit with Watchdog Timer 8-SOIC -40 to 85
Dual Processor Supervisors datasheet
PDF, 990 Кб, Версия: C, Файл опубликован: 27 мар 2008
Купить TPS3305-25DR на РадиоЛоцман.Цены — от 74 до 366 ₽ 11 предложений от 8 поставщиков Processor Supervisor 2.93V/2.25V 2 Active High/Active Low 8-Pin SOIC T/R | |||
TPS3305-25DR Texas Instruments | от 74 ₽ | ||
TPS3305-25DR Texas Instruments | 85 ₽ | ||
TPS3305-25DR Texas Instruments | 358 ₽ | ||
TPS3305-25DR Texas Instruments | 366 ₽ |
Pin | 8 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | 30525 |
Width (мм) | 3.91 |
Length (мм) | 4.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
# of Supplies Monitored | 2 |
Iq(Typ) | 40 uA |
Monitored Voltage 1 (typ)(Nom) | 1.8,2.5,3.3,5 В |
Monitored Voltage 2 (typ)(Nom) | N/A В |
Output Driver Type / Reset Output | Active-high,Active-low,Push-pull |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
Rating | Catalog |
Reset Threshold Accuracy | 2.4 % |
Special Features | Active Low Enable,Manual Reset,Watchdog Timer |
Threshold Voltage 1(Typ) | 1.68,2.25,2.93,4.55 В |
Threshold Voltage 2 (typ)(Typ) | N/A В |
Time Delay | 200 ms |
VCC(Max) | 6 В |
VCC(Min) | 2.7 В |
Watchdog Timer WDI | 1.6 sec |
Серия: TPS3305 (24)
- TPS3305-18D TPS3305-18DG4 TPS3305-18DGN TPS3305-18DGNG4 TPS3305-18DGNR TPS3305-18DGNRG4 TPS3305-18DR TPS3305-18DRG4 TPS3305-25D TPS3305-25DG4 TPS3305-25DGN TPS3305-25DGNG4 TPS3305-25DGNR TPS3305-25DGNRG4 TPS3305-25DR TPS3305-25DRG4 TPS3305-33D TPS3305-33DG4 TPS3305-33DGN TPS3305-33DGNG4 TPS3305-33DGNR TPS3305-33DGNRG4 TPS3305-33DR TPS3305-33DRG4
- Semiconductors > Power Management > Supervisor and Reset IC
TPS330525DR, TPS3305 25DR
