Datasheet Texas Instruments OPA4131UA — Даташит
Серия | OPA4131 |
Модель | OPA4131UA |
Операционные усилители общего назначения с полевым транзистором 16-SOIC от -40 до 85
General Purpose FET-Input Operational Amplifiers datasheet
PDF, 1.6 Мб, Версия: A, Файл опубликован: 21 окт 2002
Купить OPA4131UA на РадиоЛоцман.Цены — от 66 до 1 985 ₽ 31 предложений от 21 поставщиков TEXAS INSTRUMENTS OPA4131UA Operational Amplifier, Quad, 4 Amplifier, 4MHz, 10V/µs, ± 4.5V to ± 18V, SOIC, 16Pins | |||
OPA4131UA Texas Instruments | 66 ₽ | ||
OPA4131UA Texas Instruments | от 252 ₽ | ||
OPA4131UA/1K Texas Instruments | 292 ₽ | ||
OPA4131UA Texas Instruments | от 1 506 ₽ |
Pin | 16 |
Package Type | DW |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 40 |
Carrier | TUBE |
Маркировка | OPA4131UA |
Width (мм) | 7.5 |
Length (мм) | 10.3 |
Thickness (мм) | 2.35 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.65 |
Mechanical Data | Скачать |
Additional Features | N/A |
Архитектура | FET |
CMRR(Min) | 70 дБ |
CMRR(Typ) | 80 дБ |
GBW(Typ) | 4 МГц |
Input Bias Current(Max) | 50 pA |
Iq per channel(Max) | 1.75 мА |
Iq per channel(Typ) | 1.5 мА |
Количество каналов | 4 |
Offset Drift(Typ) | 2 uV/C |
Output Current(Typ) | 25 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 14SOIC: 52 mm2: 6 x 8.65(SOIC) PKG |
Rail-to-Rail | No |
Rating | Catalog |
Slew Rate(Typ) | 10 V/us |
Total Supply Voltage(Max) | 36 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 9 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 15 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 1 мВ |
- Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA4131 (11)
