Datasheet Texas Instruments TPS3852G18QDRBRQ1 — Даташит
Серия | TPS3852-Q1 |
Модель | TPS3852G18QDRBRQ1 |
Automotive High-Accuracy Voltage Supervisor With Integrated Watchdog Timer 8-SON -40 to 125
TPS3852-Q1 High-Accuracy Voltage Supervisor with Integrated Watchdog Timer datasheet
PDF, 1.3 Мб, Файл опубликован: 22 фев 2017
Купить TPS3852G18QDRBRQ1 на РадиоЛоцман.Цены — от 91 до 356 ₽ 13 предложений от 9 поставщиков Processor Supervisor 1 Active Low/Open Drain Automotive 8-Pin VSON EP T/R | |||
TPS3852G18QDRBRQ1 Texas Instruments | 91 ₽ | ||
TPS3852G18QDRBRQ1 Texas Instruments | 197 ₽ | ||
TPS3852G18QDRBRQ1 Texas Instruments | 349 ₽ | ||
TPS3852G18QDRBRQ1 Texas Instruments | по запросу |
Pin | 8 |
Package Type | DRB |
Industry STD Term | VSON |
JEDEC Code | S-PDSO-N |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | 852DB |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | .88 |
Pitch (мм) | .65 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
# of Supplies Monitored | 1 |
Iq(Typ) | 10 uA |
Monitored Voltage 1 (typ)(Nom) | 1.8,3.3 В |
Monitored Voltage 2 (typ)(Nom) | N/A В |
Output Driver Type / Reset Output | Active-low,Open-drain |
Package Group | SON |
Package Size: mm2:W x L | See datasheet (SON) PKG |
Rating | Automotive |
Reset Threshold Accuracy | 0.8 % |
Special Features | Active Low Enable,Manual Reset,Watchdog Disable,Watchdog Timer,Window Watchdog |
Threshold Voltage 1(Typ) | 1.67,1.73,3.07,3.17 В |
Threshold Voltage 2 (typ)(Typ) | N/A В |
Time Delay | 200 ms |
VCC(Max) | 6.5 В |
VCC(Min) | 1.6 В |
Watchdog Timer WDI | Programmable sec |
- Evaluation Modules & Boards: TPS3851EVM-780
TPS3851 High-Accuracy Supervisor with Window Watchdog Evaluation Module
Серия: TPS3852-Q1 (4)
- TPS3852G18QDRBRQ1 TPS3852G33QDRBRQ1 TPS3852H18QDRBRQ1 TPS3852H33QDRBRQ1
- Semiconductors > Power Management > Supervisor and Reset IC
