Datasheet Texas Instruments TPS65101RGER — Даташит
Серия | TPS65101 |
Модель | TPS65101RGER |
4-CH LCD Bias w/ Fully Int.
TPS6510x Triple Output LCD Supply With Linear Regulator and VCOM Buffer datasheet
PDF, 1.7 Мб, Версия: D, Файл опубликован: 31 авг 2016
Купить TPS65101RGER на РадиоЛоцман.Цены — от 97 до 317 ₽ 16 предложений от 12 поставщиков 4CH LCD Bias w/ Fully Int. Pos. Charge Pump, 3.3V LDO Controller, 1.6A Min. Boost Ilim & VCOM 24-VQFN -40℃ to... | |||
TPS65101RGER Texas Instruments | 97 ₽ | ||
TPS65101RGER Texas Instruments | 133 ₽ | ||
TPS65101RGER Texas Instruments | по запросу | ||
Pos. Charge Pump, 3.3V LDO Controller, 1.6A Min. Boost Ilim & VCOM 24-VQFN -40 to 85
Pin | 24 | 24 |
Package Type | RGE | RGE |
Industry STD Term | VQFN | VQFN |
JEDEC Code | S-PQFP-N | S-PQFP-N |
Package QTY | 3000 | 3000 |
Carrier | LARGE T&R | LARGE T&R |
Маркировка | TPS | 65101 |
Width (мм) | 4 | 4 |
Length (мм) | 4 | 4 |
Thickness (мм) | .88 | .88 |
Pitch (мм) | .5 | .5 |
Max Height (мм) | 1 | 1 |
DisplayType | LCD Unipolar |
IC Integration | LCD Bias |
Level Shifter/Scan Driver | N/A Ch |
Pin/Package | 24HTSSOP, 24VQFN |
Source Driver Voltage(Max) | 15 В |
Source Driver Voltage(Min) | 5 В |
Special Function | VCOM/OpAmp |
Target Application | 7 inches or less,7 to 13 inches |
Vin(Max) | 5.8 В |
Vin(Min) | 2.7 В |
- Load Disconnect for the TPS6510x (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 8 фев 2017
Many boost converters have an external rectifier diode. The input voltage of the TPS6510x main boostconverter is connected to the output voltage when the device is disabled. Due to the direct pass from theinput to the output, the converter has no short-circuit protection. This application report describes how touse a PNP transistor and some passive components to disconnect the boost converte - How to Compensate the TPS6510x and the TPS6514xPDF, 1.1 Мб, Файл опубликован: 30 авг 2016
The boost converters in the TPS6510x (TPS65100 TPS65101 TPS65105) and the TPS6514x (TPS65140 TPS65141 TPS65145) series use external loop compensation providing high flexibility in LCD supply design. If designing a typical application scheme use the recommended components from the TPS6510x datasheet (SLVS496) and the TPS6514x datasheet (SLVS497). This application note gives a deeper understand - Basic Calculation of an Inverting Buck-Boost Power Stage (Rev. A)PDF, 431 Кб, Версия: A, Файл опубликован: 28 авг 2017
This application note provides basic formulas that you need to design the power stage of an invertingbuck-boost converter. The premise is that the power switch is integrated in the IC and the rectification isdone by a diode (non-synchronous power stage). It provides all the formulas and considerations that youneed to select the external power components such as the inductor the diode and t - Generation of a VCOM buffer input using PWM signalPDF, 439 Кб, Файл опубликован: 21 дек 2015
In an LCD the backlight shines through the liquid crystal material and the voltage across the liquid crystal controls how much light shines through it. An active matrix LCD (AMLCD) contains many pixels arranged in a grid pattern. The voltage across each pixel is controlled individually so that high resolution images can be created. One terminal of every pixel is connected to a common plane. The v - Understanding Undervoltage Lockout in Power Devices (Rev. A)PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products. - Minimizing Ringing at the Switch Node of a Boost ConverterPDF, 201 Кб, Файл опубликован: 15 сен 2006
The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter. - Basic Calculation of a Boost Converter's Power Stage (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
Серия: TPS65101 (3)
- TPS65101PWP TPS65101PWPR TPS65101RGER
- Semiconductors > Power Management > LCD/OLED Display Bias Solutions
