Datasheet Texas Instruments TPS65160APWPR — Даташит
Серия | TPS65160A |
Модель | TPS65160APWPR |
4-CH LCD Bias (2.8A Min. Boost Ilim. Up to 17.5V, 2A Min. Buck Ilim) 28-HTSSOP -40 to 85
Bias Power Supply for TV and Monitor TFT LCD Panel datasheet
PDF, 1.1 Мб, Версия: C, Файл опубликован: 5 мар 2013
Купить TPS65160APWPR на РадиоЛоцман.Цены — от 87 до 484 ₽ 18 предложений от 13 поставщиков 4CH LCD Bias (2.8A Min. Boost Ilim. Up to 17.5V, 2A Min. Buck Ilim) 28-HTSSOP -40℃ to 85℃ | |||
TPS65160APWPR Texas Instruments | от 87 ₽ | ||
TPS65160APWPR Texas Instruments | 140 ₽ | ||
TPS65160APWPR Texas Instruments | 203 ₽ | ||
TPS65160APWPR Texas Instruments | 214 ₽ |
Pin | 28 |
Package Type | PWP |
Industry STD Term | HTSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Width (мм) | 4.4 |
Length (мм) | 9.7 |
Thickness (мм) | 1 |
Pitch (мм) | 0.65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
DisplayType | LCD Unipolar |
IC Integration | LCD Bias |
Pin/Package | 28HTSSOP |
Source Driver Voltage(Max) | 17.5 В |
Special Function | Adjustable Sequencing |
Target Application | 13 to 21 inches,21 inches and above |
Topology | Boost,Buck |
Vin(Max) | 14 В |
Vin(Min) | 9.2 В |
- Evaluation Modules & Boards: TPS65160EVM-194
TPS65160 Evaluation Module
- Bias Power Supply for TV and Monitor TFT LCD Panels Using the TPS65160PDF, 144 Кб, Файл опубликован: 13 июн 2006
The reference design and application examples shown in this document help implement a positive-charge pump doubler show how to drive an isolation FET and show how to perform voltage conversion with the TPS65160.The TPS65160 offers a compact power supply solution to provide all four voltages required by a thin-film transitor (TFT) LCD panel. With its high-current capabilities the device is i - Generation of a VCOM buffer input using PWM signalPDF, 439 Кб, Файл опубликован: 21 дек 2015
In an LCD the backlight shines through the liquid crystal material and the voltage across the liquid crystal controls how much light shines through it. An active matrix LCD (AMLCD) contains many pixels arranged in a grid pattern. The voltage across each pixel is controlled individually so that high resolution images can be created. One terminal of every pixel is connected to a common plane. The v - Understanding Undervoltage Lockout in Power Devices (Rev. A)PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products. - Minimizing Ringing at the Switch Node of a Boost ConverterPDF, 201 Кб, Файл опубликован: 15 сен 2006
The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter. - Basic Calculation of a Boost Converter's Power Stage (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed. - Basic Calculation of a Buck Converter's Power Stage (Rev. B)PDF, 202 Кб, Версия: B, Файл опубликован: 17 авг 2015
Серия: TPS65160A (2)
- TPS65160APWP TPS65160APWPR
- Semiconductors > Power Management > LCD/OLED Display Bias Solutions
