Datasheet Texas Instruments TSC2102IDAR — Даташит
Серия | TSC2102 |
Модель | TSC2102IDAR |
4-Wire Touch Screen Controller with Stereo DAC with HP Amplifier 32-TSSOP -40 to 85
Programmable Touch Screen Controller w/Integrat Stereo Audio DAC & Headphone Amp datasheet
PDF, 720 Кб, Версия: A, Файл опубликован: 17 июн 2004
Купить TSC2102IDAR на РадиоЛоцман.Цены — от 198 до 710 ₽ 17 предложений от 13 поставщиков 4-Wire Touch Screen Controller with Stereo DAC with HP Amplifier 32-TSSOP -40℃ to 85℃ | |||
TSC2102IDAR Texas Instruments | от 198 ₽ | ||
TSC2102IDAR Texas Instruments | 219 ₽ | ||
TSC2102IDAR Texas Instruments | 355 ₽ | ||
TSC2102IDAR Texas Instruments | от 710 ₽ |
Pin | 32 |
Package Type | DA |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | TSC2102I |
Width (мм) | 6.2 |
Length (мм) | 11 |
Thickness (мм) | 1.15 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
# Audio DACs / ADCs | 2 / 0 |
Additional Features | Int. PLL |
Analog Supply | 2.7 - 3.6 В |
Audio Codec Resolution | 24 Bits |
Audio Pd | 11 mW |
Audio Sample Rate | 53 ksps |
Control Interface | SPI |
Digital Audio Interface | I2S,R,L,DSP |
Digital Supply (up to 5 V) | 1.525 - 1.95 В |
IO Supply | 1.1 - 3.6 В |
Number of Audio Inputs / Outputs | 0 / 2 |
Package Group | TSSOP |
Package Size: mm2:W x L | 32TSSOP: 89 mm2: 8.1 x 11(TSSOP) PKG |
SAR ADC Resolution | 12 Bits |
SAR Sample Rate(Max) | 125 kSPS |
SNR Audio DAC / ADC(Typ) | 96 / - дБ |
Touch Panel | 4-Wire |
Vref | Int Int/Ext |
- TSC2100 WinCE Generic DriversPDF, 206 Кб, Файл опубликован: 8 мар 2004
This application report develops and presents the TSC2100 touchscreen and audio WinCE drivers. These generic drivers can be used on or adapted to different processors or processor platforms. The associated driver code was tested with the Intel(TM) Lubbock and MainStone platforms. - Using the PGA Function in TSC210x/AIC26/AIC28/DAC26 DevicesPDF, 453 Кб, Файл опубликован: 3 июн 2005
TI's touch screen and audio codec/DAC devices, such as the TSC2100, TSC2101, TSC2102, TLV320AIC26, TLV320AIC28, and the TLC320DAC26, have one or more audio-band programmable gain amplifiers (PGA) in their input circuitry. This application report describes how to implement this PGA function using the TLV320DAC26 as an example. - Programming Audio Power Up/Down on TSC210x & TLV320AIC26/28 (Rev. A)PDF, 61 Кб, Версия: A, Файл опубликован: 5 май 2005
This application report presents some general and practical programming sequences for the audio power up/down of Texas Instruments TSC2100/TSC2102/TLV320AIC26 and TSC2101/TLV320AIC28 devices, so as to avoid a possible malfunction or errors during and after power up or down. - Programming Sequences and Tips for TSC2000/2200/230x ApplicationsPDF, 206 Кб, Файл опубликован: 8 мар 2004
To apply the touchscreen function of a TSC2000, TSC2200, or TSC230x device, certain software programming sequences are crucial during the TSC initialization and data reading and are also helpful during the TSC mode changing. This application report presents some practical programming sequences. Additionally, some program and debug tips are provided. - Interface TSC Through McBSPPDF, 221 Кб, Файл опубликован: 28 окт 2004
This application report develops and presents the methodology to interface TI's touch screen controller products and multichannel buffered serial ports (McBSP) through SPI and I2S buses. The interface software code is designed and tested using the TMS320VC5416 DSK and the TSC2100 EVM. - How to Set the TSC/AIC EVM to Record & Playback Audio or Other Sound Through PCPDF, 480 Кб, Файл опубликован: 14 дек 2004
Record and playback audio, sound, or voice on a TI touch screen controller (TSC) or audio codec (AIC) EVM system by means of the associated software running on a PC system. The PC and EVM are connected using a USB cable. This application report gives an example to demonstrate how to do this through a Windows XP? PC system. The block diagram and connection are shown in Figure 1.
Серия: TSC2102 (2)
- TSC2102IDA TSC2102IDAR
- Semiconductors > Audio > Touch Screen Controller with Audio
