Datasheet Texas Instruments UCC2946DTR — Даташит
Серия | UCC2946 |
Модель | UCC2946DTR |
Microprocessor Supervisor with Watchdog Timer 8-SOIC -40 to 85
Microprocessor Supervisor with Watchdog Timer datasheet
PDF, 1.2 Мб, Версия: F, Файл опубликован: 21 ноя 2007
Купить UCC2946DTR на РадиоЛоцман.Цены — от 113 до 662 ₽ 21 предложений от 14 поставщиков Processor Supervisor 1.235V 2.1V to 5.5V 8Pin SOIC T/R | |||
UCC2946DTR Texas Instruments | 113 ₽ | ||
UCC2946DTR Texas Instruments | 141 ₽ | ||
UCC2946DTR Texas Instruments | по запросу | ||
Pin | 8 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | UCC2946 |
Width (мм) | 3.91 |
Length (мм) | 4.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
# of Supplies Monitored | 1 |
Iq(Typ) | 10 uA |
Monitored Voltage 1 (typ)(Nom) | Adjustable В |
Monitored Voltage 2 (typ)(Nom) | N/A В |
Output Driver Type / Reset Output | Active-low,Push-pull |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
Rating | Catalog |
Reset Threshold Accuracy | 2 % |
Special Features | Watchdog Timer |
Threshold Voltage 1(Typ) | Adjustable В |
Threshold Voltage 2 (typ)(Typ) | N/A В |
Time Delay | Programmable ms |
VCC(Max) | 5.5 В |
VCC(Min) | 2.1 В |
Watchdog Timer WDI | Programmable sec |
- Disabling the Watchdog Timer for TI's Family of SupervisorsPDF, 138 Кб, Файл опубликован: 30 окт 2003
In many microprocessor applications where a watchdog supervisor, such as the TPS3306, is required, it may be necessary to disable the watchdog. This is particularly true when software boot times exceed the watchdog time-out period. This application note describes a circuit that can be used to selectively disable the watchdog timer. - Optimizing Resistor Dividers at a Comparator (Rev. A)PDF, 120 Кб, Версия: A, Файл опубликован: 3 июн 2013
Серия: UCC2946 (8)
- Semiconductors > Power Management > Supervisor and Reset IC
