Datasheet Texas Instruments VCBUP7CT1 — Даташит
Серия | TMS320DM6467T |
Модель | VCBUP7CT1 |
Digital Media System-on-Chip 529-FCBGA 0 to 85
TMS320DM6467T Digital Media System-on-Chip datasheet
PDF, 2.1 Мб, Версия: C, Файл опубликован: 11 июл 2012
Купить VCBUP7CT1 на РадиоЛоцман.Цены — от 10 471 до 13 438 ₽ new in stock for immediate delivery | |||
VCBUP7CT1 Texas Instruments | 10 471 ₽ | ||
VCBUP7CT1 Texas Instruments | 13 290 ₽ | ||
VCBUP7CT1 Texas Instruments | 13 438 ₽ | ||
VCBUP7CT1 Texas Instruments | по запросу |
Pin | 529 | 529 |
Package Type | CUT | CUT |
Package QTY | 84 | 84 |
Carrier | JEDEC TRAY (5+1) | JEDEC TRAY (5+1) |
Маркировка | TMS320 | DM6467TCUT1 |
Width (мм) | 19 | 19 |
Length (мм) | 19 | 19 |
Thickness (мм) | 2.65 | 2.65 |
ARM CPU | 1 ARM9 |
ARM MHz | 500 Max. |
Applications | Communications and Telecom,Consumer Electronics,Energy,Industrial,Security,Video and Imaging |
DRAM | DDR2 |
DSP | 1 C64x |
DSP MHz | 1000 Max. |
EMAC | 10/100/1000 |
I2C | 1 |
On-Chip L2 Cache | 128 KB (DSP) |
Operating Systems | DSP/BIOS,Linux,VLX |
Рабочий диапазон температур | от -40 до 85,0 до 85 C |
PCI/PCIe | 1 32-Bit [66 MHz] |
Pin/Package | 529FCBGA |
Rating | Catalog |
SPI | 1 |
UART | 3 SCI |
Video Acceleration | 2 HDVICPs |
Video Port | 1 for Dual SD or Single HD Display,1 for Dual SD or Single HD or Single Raw Capture,VPIF Configurable |
Video Resolution/Frame Rate | D1 or Less,720p,1080i/p |
- JTAG Emulators/ Analyzers: TMDSEMU200-U
XDS200 USB Debug Probe
Статус продукта: В производстве (Рекомендуется для новых разработок) - JTAG Emulators/ Analyzers: TMDSEMU560V2STM-UE
- TMS320DM6467T Power Consumption SummaryPDF, 132 Кб, Файл опубликован: 13 ноя 2009
This application report discusses the power consumption of the Texas Instruments TMS320DM6467T digital media System-on-Chip (DMSoC). Power consumption on the DM6467T device is highly application-dependent; therefore, a spreadsheet that estimates power consumption is provided along with this document. To obtain good results from the spreadsheet, realistic usage parameters must be entered (see Secti - Using the TMS320DM646x DMSoC Bootloader (Rev. D)PDF, 136 Кб, Версия: D, Файл опубликован: 4 мар 2011
This document describes the functionality of the TMS320DM6467 Digital Media System-on-Chip (DMSoC) ARM ROM bootloader (RBL) software. The ARM ROM bootloader resides in the ROM of the device beginning at address 0x00008000. The RBL implements methods for booting in the listed modes and uses boot configuration pins to determine boot mode. If an improper boot mode is chosen, or an error is detected d - PCI Express to TMS320DM646x PCI Interface Through XIO2000A BridgePDF, 119 Кб, Файл опубликован: 3 фев 2009
The Texas Instruments DM646x devices support interfacing to a peripheral component interconnect (PCI) bus through its PCI port. The system or the application may contain a PCI ExpressВ® interface. In order to connect the PCI Express bus to the DM646x PCI bus, an XIO2000A translation bridge is used. XIO2000A is a PCI Express to PCI/PCI-Xв„ў bus translation bridge. - Using the Video Port of TMS320DM646x (Rev. A)PDF, 181 Кб, Версия: A, Файл опубликован: 6 апр 2010
This application report has supplemental information about using the DM646x video port. The tips and tricks in this document are useful in video security applications as well as other applications that make use of the video port. - TMS320DM6467 to TMS320DM6467T Migration Guide (Rev. B)PDF, 40 Кб, Версия: B, Файл опубликован: 8 июн 2010
This application report describes an overview of the necessary changes to migrate a DM6467-based design from a DM6467 device (594 MHz or 729 MHz) to a DM6467T (1GHz) device. The DM6467T device requires the changes listed in this document for proper operation. Other system changes may be required to accommodate new speeds or capabilities in the system. - Multiple TMS320DM6467 PCI InterfacePDF, 85 Кб, Файл опубликован: 10 фев 2009
The DM6467 contains a PCI interface that allows connecting it to a PCI bus in order to communicate with the other peripherals in the system. The DM6467 PCI has a 32-bit data bus. The operating frequency is specified in the device-specific data sheet. This document shows different ways to interface DM6467 devices with the PCI bus. - Building a Small Embedded Linux Kernel Example (Rev. A)PDF, 1.3 Мб, Версия: A, Файл опубликован: 27 май 2008
Building a Small Embedded Linux Kernel Example Application Report - Running a TMS320C64x+ Codec Across TMS320C64x+ Based DSP PlatformsPDF, 969 Кб, Файл опубликован: 24 сен 2009
This application report describes the device differences to be taken care for running the C64x+™ video codec software on different C64x+ based platforms. This document assumes that the codec software is developed for the C64x+ digital signal processor (DSP) core. As many TI platforms have a C64x+ DSP this document gives the details for running the standalone codec software on a C64x+ platfo - TMS320C64x to TMS320C64x+ CPU Migration Guide (Rev. A)PDF, 310 Кб, Версия: A, Файл опубликован: 20 окт 2005
This document describes migration from the Texas Instruments TMS320C64xв„ў digital signal processor (DSP) to the TMS320C64x+в„ў DSP. The objective of this document is to indicate differences between the two cores and to briefly describe new features. Functionality in the devices that is identical is not included. For detailed information about either device, see the TMS320C64x/C64x+ DSP - Understanding TI's PCB Routing Rule-Based DDR Timing Specification (Rev. A)PDF, 93 Кб, Версия: A, Файл опубликован: 17 июл 2008
This application report motivates the way the DDR high-speed timing requirements are now going to be communicated to system designers. The traditional method of using data sheet parameters and simulation models is tedious. The system designer uses this information to evaluate whether timing specifications are met and can be expected to operate reliably.Ultimately, the real question the hardwa - Thermal Considerations for the DM64xx, DM64x, and C6000 DevicesPDF, 127 Кб, Файл опубликован: 20 май 2007
As integrated circuit (IC) components become more complex, the challenge of producing an end product with superior thermal performance increases. Thermal performance is a system level concern, impacted by IC packaging as well as by printed circuit board (PCB) design. This application report addresses the thermal considerations for the TMS320DM64xx, TMS320DM64x, and TMS320C6000в„ў DSP devices. - Introduction to TMS320C6000 DSP OptimizationPDF, 535 Кб, Файл опубликован: 6 окт 2011
Серия: TMS320DM6467T (10)
- Semiconductors > Processors > Digital Signal Processors > Media Processors > Digital Video Processors
