Datasheet Linear Technology LT8610AC-1 — Даташит
СерияLT8610AC-1
42V, 3.5A Synchronous Step-Down Regulator with 2.5µA Quiescent Current
Datasheet LT8610AC, LT8610AC-1
PDF, 552 Кб, Язык: анг., Файл закачен: 19 сен 2017, Страниц: 26
42V, 3.5A Synchronous Step-Down Regulator with 2.5μA Quiescent Current
LT8610AC: 5.5-42Vin [email protected]
LT8610ACEMSE-1#PBFLT8610ACEMSE-1#TRPBFLT8610ACHMSE-1#PBFLT8610ACHMSE-1#TRPBFLT8610ACIMSE-1#PBFLT8610ACIMSE-1#TRPBF
N123456
КорпусMS-16E
Габаритный чертеж корпуса
MS-16E
MS-16E
MS-16E
MS-16E
MS-16E
Код корпусаMSEMSEMSEMSEMSEMSE
Индекс корпуса05-08-166705-08-166705-08-166705-08-166705-08-166705-08-1667
Количество выводов161616161616
Parameters / ModelsLT8610ACEMSE-1#PBFLT8610ACEMSE-1#TRPBFLT8610ACHMSE-1#PBFLT8610ACHMSE-1#TRPBFLT8610ACIMSE-1#PBFLT8610ACIMSE-1#TRPBF
АрхитектураConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current Mode
Design ToolsLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD Model
Экспортный контрольнетнетнетнетнетнет
Основные особенностиBurst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodBurst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodBurst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodBurst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodBurst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodBurst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power Good
Тактовая частота, kHz220022002200220022002200
Frequency Adjust Range200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz
Frequency Sync Range200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz
Integrated Inductorнетнетнетнетнетнет
Ishutdown, мкА111111
Isupply, мА0.0170.0170.0170.0170.0170.017
Max Phases111111
Monolithicдададададада
Количество выходов111111
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85от -40 до 125от -40 до 125от -40 до 85от -40 до 85
Выходной ток, A3.53.53.53.53.53.5
Polyphaseнетнетнетнетнетнет
Switch Current, A6.76.76.76.76.76.7
Synchronousдададададада
TopologyBuckBuckBuckBuckBuckBuck
Vin Max, В424242424242
Vin Min, В333333
Vout Max, В41.841.841.841.841.841.8
Vout Min, В0.80.80.80.80.80.8
Vref Accuracy Over Temp, %1.51.51.51.51.51.5
RoHSСовместимСовместимСовместимСовместимСовместимСовместим
LT8610AC
  • Power Management > Switching Regulator > Step-Down (Buck) Regulators > Micropower Buck Regulators | Internal Power Switch Buck | High Input Voltage Buck
  • Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Switching Regulators
На английском языке: Datasheet Linear Technology LT8610AC-1
