Datasheet Linear Technology LTC3220-1 — Даташит
СерияLTC3220-1
360mA Universal 18-Channel LED Driver
LTC3220/LTC3220-1 - 360mA Universal 18-Channel LED Driver
PDF, 279 Кб, Версия: D, Файл закачен: 27 сен 2017
ТаймЧипс
LTC3220-1по запросу
LTC3220_1по запросу
LTC3220EPF-1#PBFLTC3220EPF-1#TRPBFLTC3220IPF-1#PBFLTC3220IPF-1#TRPBF
N1234
Корпус4x4 UTQFN-28
Габаритный чертеж корпуса
4x4 UTQFN-28
4x4 UTQFN-28
4x4 UTQFN-28
Код корпусаPFPFPFPF
Индекс корпуса05-08-175905-08-175905-08-175905-08-1759
Количество выводов28282828
Parameters / ModelsLTC3220EPF-1#PBFLTC3220EPF-1#TRPBFLTC3220IPF-1#PBFLTC3220IPF-1#TRPBF
Demo BoardsDC1265A-A,DC1265A-BDC1265A-A,DC1265A-BDC1265A-A,DC1265A-BDC1265A-A,DC1265A-B
Экспортный контрольнетнетнетнет
Основные особенностиI2C ControlI2C ControlI2C ControlI2C Control
Тактовая частота, kHz850850850850
Ishutdown, мкА3.23.23.23.2
Isupply, мА.580.580.580.580
Max Number of LEDs18 (parallel)18 (parallel)18 (parallel)18 (parallel)
Monolithicдададада
Количество выходов18181818
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85от -40 до 85от -40 до 85
Выходной ток, A0.360.360.360.36
Synchronousнетнетнетнет
TopologyCharge Pump, LED DriverCharge Pump, LED DriverCharge Pump, LED DriverCharge Pump, LED Driver
Vin Max, В5.55.55.55.5
Vin Min, В2.92.92.92.9
Vout Max, В5.55.55.55.5
RoHSСовместимСовместимСовместимСовместим
LTC3220
  • LTC3220/LTC3220-1 User’s Guide &mdash AN115
    PDF, 224 Кб, Файл опубликован: 28 фев 2008
    This application note illustrates how to program and use the unique features of the LTC3220/LTC3220-1 Universal LED (ULED) Driver. These features include individually controlling, gradually turning on and off, or blinking up to 18 LEDs. This device may also be used to provide digital signal(s) to other devices while in shutdown using a strong pull-down general purpose output (GPO) and an external power source. Current limited GPO mode may also be used to control other devices using the charge pump output (CPO) of the device or an external supply. A programmable shutdown feature allows the device to go into and out of shutdown returning to its pre-shutdown state. These features give the user vast flexibility and control of LEDs and other devices while saving memory space, programming time, I2C traffic, and even battery power.
  • Power Management > Inductorless (Charge Pump) DC/DC Converters > Inductorless (Charge Pump) LED Drivers
На английском языке: Datasheet Linear Technology LTC3220-1
Публикации по теме
