Datasheet Texas Instruments UC3906N — Даташит
Серия | UC3906 |
Модель | UC3906N |
Зарядное устройство для линейных свинцово-кислотных аккумуляторов 16-PDIP от -20 до 70
Sealed Lead-Acid Battery Charger datasheet
PDF, 4.3 Мб, Версия: C, Файл опубликован: 23 май 2005
Купить UC3906N на РадиоЛоцман.Цены — от 219 до 2 345 ₽ 29 предложений от 20 поставщиков TEXAS INSTRUMENTS UC3906N Battery Charger for 4 Cells of Lead Acid battery, 40V input, 2A charge, DIP-16 | |||
UC3906N Texas Instruments | 219 ₽ | ||
UC3906N Texas Instruments | 227 ₽ | ||
UC3906N National Semiconductor | 599 ₽ | ||
UC3906N Texas Instruments | по запросу |
Статус продукта | NRND (Не рекомендуется для новых разработок) |
Pin | 16 |
Package Type | N |
Industry STD Term | PDIP |
JEDEC Code | R-PDIP-T |
Package QTY | 25 |
Carrier | TUBE |
Маркировка | UC3906N |
Width (мм) | 6.35 |
Length (мм) | 19.3 |
Thickness (мм) | 3.9 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
Рекомендуемая замена
Replacement | BQ24450DW |
Replacement Code | F |
- U-104 Improved Charging Methods for Lead-Acid Batteries Using the UC3906PDF, 331 Кб, Файл опубликован: 5 сен 1999
This application note describes the operation and application of the UC3906 sealed lead-acid battery-charger IC. Several charging circuits using this IC are described, along with expected improvements in battery performance. This note also discusses uses for the many auxiliary functions of the part. - U-131 Simple Switchmode Lead-Acid Battery ChargerPDF, 206 Кб, Файл опубликован: 5 сен 1999
Lead-acid batteries are finding considerable use as bothprimary and backup power sources. For complete batteryutilization the charger circuit must charge the batteryto full capacity while minimizing over-charging forextended battery life. Since battery capacity varies withtemperature the charger must vary the amount of chargewith temperature to realize maximum capacity and life.Si
Серия: UC3906 (10)
- Semiconductors > Power Management > Battery Management Products > Battery Charger IC
