Datasheet Intersil ISL9305H — Даташит
ПроизводительIntersil
СерияISL9305H
3MHz Dual 1.5A Step-Down Converters and Dual Low-Input LDOs with I2C Compatible Interface
ISL9305H Datasheet
PDF, 822 Кб, Версия: 2017-11-15, Файл закачен: 9 май 2018
ISL9305H
Intersil
ISL9305IRTHAANLZ-TISL9305IRTHBCNLZ-TISL9305IRTHBFNCZ-TISL9305IRTHWBNLZ-TISL9305IRTHWCLBZ-TISL9305IRTHWCNLZ-TISL9305IRTHWCNYZ-TISL9305IRTHWLNCZ-T
N12345678
Intersil L16.4X4GIntersil L16.4X4GIntersil L16.4X4GIntersil L16.4X4GIntersil L16.4X4GIntersil L16.4X4GIntersil L16.4X4GIntersil L16.4X4G
Корпус16 Ld TQFN T+R
Габаритный чертеж корпуса
16 Ld TQFN T+R
16 Ld TQFN T+R
16 Ld TQFN T+R
16 Ld TQFN T+R
16 Ld TQFN T+R
16 Ld TQFN T+R
16 Ld TQFN T+R
Индекс корпусаL16.4X4GL16.4X4GL16.4X4GL16.4X4GL16.4X4GL16.4X4GL16.4X4GL16.4X4G
Пиковая температура пайки260°C260°C260°C260°C260°C260°C260°C260°C
Количество выводов1616161616161616
СемействоTQFNTQFNTQFNTQFNTQFNTQFNTQFNTQFN
Parameters / ModelsISL9305IRTHAANLZ-T
ISL9305IRTHAANLZ-T
ISL9305IRTHBCNLZ-T
ISL9305IRTHBCNLZ-T
ISL9305IRTHBFNCZ-T
ISL9305IRTHBFNCZ-T
ISL9305IRTHWBNLZ-T
ISL9305IRTHWBNLZ-T
ISL9305IRTHWCLBZ-T
ISL9305IRTHWCLBZ-T
ISL9305IRTHWCNLZ-T
ISL9305IRTHWCNLZ-T
ISL9305IRTHWCNYZ-T
ISL9305IRTHWCNYZ-T
ISL9305IRTHWLNCZ-T
ISL9305IRTHWLNCZ-T
# of Outputs44444444
Control TypeCurrent ModeCurrent ModeCurrent ModeCurrent ModeCurrent ModeCurrent ModeCurrent ModeCurrent Mode
Description3MHz Dual 1.5A Step-Down Converters and Dual Low-Input LDOs with I2C Compatible Interface3MHz Dual 1.5A Step-Down Converters and Dual Low-Input LDOs with I2C Compatible Interface3MHz Dual 1.5A Step-Down Converters and Dual Low-Input LDOs with I2C Compatible Interface3MHz Dual 1.5A Step-Down Converters and Dual Low-Input LDOs with I2C Compatible Interface3MHz Dual 1.5A Step-Down Converters and Dual Low-Input LDOs with I2C Compatible Interface3MHz Dual 1.5A Step-Down Converters and Dual Low-Input LDOs with I2C Compatible Interface3MHz Dual 1.5A Step-Down Converters and Dual Low-Input LDOs with I2C Compatible Interface3MHz Dual 1.5A Step-Down Converters and Dual Low-Input LDOs with I2C Compatible Interface
IOUT (max) (A)1.51.51.51.51.51.51.51.5
IQ50 µA50 µA50 µA50 µA50 µA50 µA50 µA50 µA
Max Duty Cycle (%)See DatasheetSee DatasheetSee DatasheetSee DatasheetSee DatasheetSee DatasheetSee DatasheetSee Datasheet
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
PORYesYesYesYesYesYesYesYes
Peak Efficiency (%)8787878787878787
Qualification LevelStandardStandardStandardStandardStandardStandardStandardStandard
SYNCH CapabilityNoNoNoNoNoNoNoNo
Switching Freq. (max)3.4 MHz3.4 MHz3.4 MHz3.4 MHz3.4 MHz3.4 MHz3.4 MHz3.4 MHz
Switching Freq. (min)2.6 MHz2.6 MHz2.6 MHz2.6 MHz2.6 MHz2.6 MHz2.6 MHz2.6 MHz
TopologyBuckBuckBuckBuckBuckBuckBuckBuck
VIN (max) (V)5.55.55.55.55.55.55.55.5
VIN (min) (V)2.52.52.52.52.52.52.52.5
VOUT (max) (V)5.55.55.55.55.55.55.55.5
VOUT (min) (V)0.80.80.80.80.80.80.80.8
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
  • Power Management > PMIC > Integrated FET Regulators
На английском языке: Datasheet Intersil ISL9305H
