Datasheet Intersil ISL91110 — Даташит
Производитель | Intersil |
Серия | ISL91110 |
High Current Buck Boost Switching Regulator Delivering 2A of Continuous Output Current
ISL91110 Datasheet
PDF, 811 Кб, Версия: 2017-11-15, Файл закачен: 9 май 2018
ISL91110IR Datasheet
PDF, 733 Кб, Версия: 2017-11-15, Файл закачен: 9 май 2018
Купить ISL91110 на РадиоЛоцман.Цены — от 71 до 248 ₽ 15 предложений от 9 поставщиков Buck-Boost Switching Regulator IC Positive Fixed 3.3V 1 Output 2A 25-UFBGA, WLCSP | |||
ISL91110IINZ-T Intersil | 71 ₽ | ||
ISL91110IINZ-T Intersil | 72 ₽ | ||
ISL91110IINZ-T | от 78 ₽ | ||
ISL91110IIAZ-T Renesas | 248 ₽ |
Parameters / Models | ISL91110II2AZ-T | ISL91110II2AZ-T7A | ISL91110IIAZ-T | ISL91110IIAZ-T7A | ISL91110IINZ-T | ISL91110IINZ-T7A | ISL91110IR2AZ-T | ISL91110IR2AZ-T7A | ISL91110IRAZ-T | ISL91110IRAZ-T7A | ISL91110IRNZ-T | ISL91110IRNZ-T7A |
# of Outputs | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Control Type | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode |
Description | High Current Buck Boost Switching Regulator Delivering 2A of Continuous Output Current | High Current Buck Boost Switching Regulator Delivering 2A of Continuous Output Current | High Current Buck Boost Switching Regulator Delivering 2A of Continuous Output Current | High Current Buck Boost Switching Regulator Delivering 2A of Continuous Output Current | High Current Buck Boost Switching Regulator Delivering 2A of Continuous Output Current | High Current Buck Boost Switching Regulator Delivering 2A of Continuous Output Current | High Current Buck Boost Switching Regulator Delivering 2A of Continuous Output Current | High Current Buck Boost Switching Regulator Delivering 2A of Continuous Output Current | High Current Buck Boost Switching Regulator Delivering 2A of Continuous Output Current | High Current Buck Boost Switching Regulator Delivering 2A of Continuous Output Current | High Current Buck Boost Switching Regulator Delivering 2A of Continuous Output Current | High Current Buck Boost Switching Regulator Delivering 2A of Continuous Output Current |
IOUT (max) (A) | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
IQ | 35 µA | 35 µA | 35 µA | 35 µA | 35 µA | 35 µA | 35 µA | 35 µA | 35 µA | 35 µA | 35 µA | 35 µA |
Max Duty Cycle (%) | - | - | - | - | - | - | - | - | - | - | - | - |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
POR | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Peak Efficiency (%) | 96 | 96 | 96 | 96 | 96 | 96 | 96 | 96 | 96 | 96 | 96 | 96 |
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
SYNCH Capability | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Switching Freq. (max) | 2.9 MHz | 2.9 MHz | 2.9 MHz | 2.9 MHz | 2.9 MHz | 2.9 MHz | 2.9 MHz | 2.9 MHz | 2.9 MHz | 2.9 MHz | 2.9 MHz | 2.9 MHz |
Switching Freq. (min) | 2.1 MHz | 2.1 MHz | 2.1 MHz | 2.1 MHz | 2.1 MHz | 2.1 MHz | 2.1 MHz | 2.1 MHz | 2.1 MHz | 2.1 MHz | 2.1 MHz | 2.1 MHz |
Topology | Buck-Boost | Buck-Boost | Buck-Boost | Buck-Boost | Buck-Boost | Buck-Boost | Buck-Boost | Buck-Boost | Buck-Boost | Buck-Boost | Buck-Boost | Buck-Boost |
VIN (max) (V) | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
VIN (min) (V) | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 |
VOUT (max) (V) | 5.2 | 5.2 | 5.2 | 5.2 | 5.2 | 5.2 | 5.2 | 5.2 | 5.2 | 5.2 | 5.2 | 5.2 |
VOUT (min) (V) | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
ISL91110II2AZ-T | ISL91110II2AZ-T7A | ISL91110IIAZ-T | ISL91110IIAZ-T7A | ISL91110IINZ-T | ISL91110IINZ-T7A | ISL91110IR2AZ-T | ISL91110IR2AZ-T7A | ISL91110IRAZ-T | ISL91110IRAZ-T7A | ISL91110IRNZ-T | ISL91110IRNZ-T7A | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: ISL91110 (12)
- Power Management > Switching Regulators > Integrated FET Regulators
