Datasheet Intersil ISL91106A — Даташит
Производитель | Intersil |
Серия | ISL91106A |
High Efficiency Buck-Boost Regulator with 4.2A Switches and Bypass Mode
ISL91106, ISL91106A Data Short
PDF, 205 Кб, Версия: 2017-11-01, Файл закачен: 9 май 2018
Купить ISL91106AIIAZ-T на РадиоЛоцман.Цены — от 65 до 93 ₽ 6 предложений от 6 поставщиков Buck-Boost Switching Regulator IC Positive Adjustable (Fixed) 1V (3.3V, 3.4V) 1 Output 2A 15-UFBGA, WLCSP | |||
ISL91106AIIAZ-T Intersil | 65 ₽ | ||
ISL91106AIIAZ-T Renesas | 91 ₽ | ||
ISL91106AIIAZ-T Renesas | 93 ₽ | ||
ISL91106AIIAZ-T Renesas | по запросу |
ISL91106AIIAZ-T | ISL91106AIINZ-T | ISL91106AIIQZ-T | |
N | 1 | 2 | 3 |
Корпус | 15 Ld WLCSP T+R Габаритный чертеж корпуса | 15 Ld WLCSP T+R Габаритный чертеж корпуса | 15 Ld WLCSP T+R Габаритный чертеж корпуса |
Индекс корпуса | W3X5.15 | W3X5.15 | W3X5.15 |
Пиковая температура пайки | 260°C | 260°C | 260°C |
Количество выводов | 15 | 15 | 15 |
Семейство | WLCSP-TKCURDL | WLCSP-TKCURDL | WLCSP-TKCURDL |
Parameters / Models | ISL91106AIIAZ-T | ISL91106AIINZ-T | ISL91106AIIQZ-T |
# of Outputs | 1 | 1 | 1 |
Control Type | Current Mode | Current Mode | Current Mode |
Description | High Efficiency Buck-Boost Regulator with 4.2A Switches and Bypass Mode | High Efficiency Buck-Boost Regulator with 4.2A Switches and Bypass Mode | High Efficiency Buck-Boost Regulator with 4.2A Switches and Bypass Mode |
IOUT (max) (A) | 2.1 | 2.1 | 2.1 |
IQ | 45 µA | 45 µA | 45 µA |
Max Duty Cycle (%) | - | - | - |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 |
POR | Yes | Yes | Yes |
Peak Efficiency (%) | 96 | 96 | 96 |
Qualification Level | Standard | Standard | Standard |
SYNCH Capability | No | No | No |
Switching Freq. (max) | 2.75 MHz | 2.75 MHz | 2.75 MHz |
Switching Freq. (min) | 2.25 MHz | 2.25 MHz | 2.25 MHz |
Topology | Buck-Boost | Buck-Boost | Buck-Boost |
VIN (max) (V) | 5.5 | 5.5 | 5.5 |
VIN (min) (V) | 1.8 | 1.8 | 1.8 |
VOUT (max) (V) | 5.2 | 5.2 | 5.2 |
VOUT (min) (V) | 1 | 1 | 1 |
Серия: ISL91106A (3)
- Power Management > Switching Regulators > Integrated FET Regulators
