Datasheet Intersil ISL8016 — Даташит
Производитель | Intersil |
Серия | ISL8016 |
6A Low Quiescent Current High Efficiency Synchronous Buck Regulator
ISL8016 Datasheet
PDF, 1.5 Мб, Версия: 2017-10-20, Файл закачен: 9 май 2018
Купить ISL8016 на РадиоЛоцман.Цены — от 86 до 824 ₽ 28 предложений от 17 поставщиков Импульсные преобразователи постоянного тока (DC/DC) 6A ADJ VOUT LW QUIES CENT CUR SYNC BUCK | |||
ISL8016IRAJZ ISL8560IRZ ISL95813HRZ ISL6558IRZ ISL95870BHRZ ISL95520HRZ ISL6271ACRZ ISL97671AIRZ ISL7100IBZ ISL85403FRZ IC, | 86 ₽ | ||
ISL8016IRAJZ-T Renesas | 135 ₽ | ||
ISL8016IRAJZ Renesas | по запросу | ||
ISL8016IRAJZ Intersil | по запросу |
Parameters / Models | ISL8016IR12Z | ISL8016IR12Z-T | ISL8016IR12Z-T7A | ISL8016IR15Z | ISL8016IR15Z-T | ISL8016IR15Z-T7A | ISL8016IR18Z | ISL8016IR18Z-T | ISL8016IR18Z-T7A | ISL8016IR25Z | ISL8016IR25Z-T | ISL8016IR25Z-T7A | ISL8016IR33Z | ISL8016IR33Z-T | ISL8016IR33Z-T7A | ISL8016IRAJZ | ISL8016IRAJZ-T | ISL8016IRAJZ-T7A |
# of Outputs | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
BOM Total Footprint | 96.8 mm2 | 96.8 mm2 | 96.8 mm2 | 96.8 mm2 | 96.8 mm2 | 96.8 mm2 | 96.8 mm2 | 96.8 mm2 | 96.8 mm2 | 96.8 mm2 | 96.8 mm2 | 96.8 mm2 | 96.8 mm2 | 96.8 mm2 | 96.8 mm2 | 96.8 mm2 | 96.8 mm2 | 96.8 mm2 |
Control Type | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode |
Description | 6A Low Quiescent Current High Efficiency Synchronous Buck Regulator | 6A Low Quiescent Current High Efficiency Synchronous Buck Regulator | 6A Low Quiescent Current High Efficiency Synchronous Buck Regulator | 6A Low Quiescent Current High Efficiency Synchronous Buck Regulator | 6A Low Quiescent Current High Efficiency Synchronous Buck Regulator | 6A Low Quiescent Current High Efficiency Synchronous Buck Regulator | 6A Low Quiescent Current High Efficiency Synchronous Buck Regulator | 6A Low Quiescent Current High Efficiency Synchronous Buck Regulator | 6A Low Quiescent Current High Efficiency Synchronous Buck Regulator | 6A Low Quiescent Current High Efficiency Synchronous Buck Regulator | 6A Low Quiescent Current High Efficiency Synchronous Buck Regulator | 6A Low Quiescent Current High Efficiency Synchronous Buck Regulator | 6A Low Quiescent Current High Efficiency Synchronous Buck Regulator | 6A Low Quiescent Current High Efficiency Synchronous Buck Regulator | 6A Low Quiescent Current High Efficiency Synchronous Buck Regulator | 6A Low Quiescent Current High Efficiency Synchronous Buck Regulator | 6A Low Quiescent Current High Efficiency Synchronous Buck Regulator | 6A Low Quiescent Current High Efficiency Synchronous Buck Regulator |
IOUT (max) (A) | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 |
IQ | 70 µA | 70 µA | 70 µA | 70 µA | 70 µA | 70 µA | 70 µA | 70 µA | 70 µA | 70 µA | 70 µA | 70 µA | 70 µA | 70 µA | 70 µA | 70 µA | 70 µA | 70 µA |
Max Duty Cycle (%) | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
POR | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Peak Efficiency (%) | 97 | 97 | 97 | 97 | 97 | 97 | 97 | 97 | 97 | 97 | 97 | 97 | 97 | 97 | 97 | 97 | 97 | 97 |
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
SYNCH Capability | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Switching Freq. (max) | 4 MHz | 4 MHz | 4 MHz | 4 MHz | 4 MHz | 4 MHz | 4 MHz | 4 MHz | 4 MHz | 4 MHz | 4 MHz | 4 MHz | 4 MHz | 4 MHz | 4 MHz | 4 MHz | 4 MHz | 4 MHz |
Switching Freq. (min) | 0.5 MHz | 0.5 MHz | 0.5 MHz | 0.5 MHz | 0.5 MHz | 0.5 MHz | 0.5 MHz | 0.5 MHz | 0.5 MHz | 0.5 MHz | 0.5 MHz | 0.5 MHz | 0.5 MHz | 0.5 MHz | 0.5 MHz | 0.5 MHz | 0.5 MHz | 0.5 MHz |
Topology | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck |
VIN (max) (V) | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
VIN (min) (V) | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 |
VOUT (max) (V) | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
VOUT (min) (V) | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 |
ISL8016IR12Z | ISL8016IR12Z-T | ISL8016IR12Z-T7A | ISL8016IR15Z | ISL8016IR15Z-T | ISL8016IR15Z-T7A | ISL8016IR18Z | ISL8016IR18Z-T | ISL8016IR18Z-T7A | ISL8016IR25Z | ISL8016IR25Z-T | ISL8016IR25Z-T7A | ISL8016IR33Z | ISL8016IR33Z-T | ISL8016IR33Z-T7A | ISL8016IRAJZ | ISL8016IRAJZ-T | ISL8016IRAJZ-T7A | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: ISL8016 (18)
- Power Management > Switching Regulators > Integrated FET Regulators
