Datasheet Intersil EL7530IY-T13 — Даташит
Monolithic 600mA Step-Down Regulator with Low Quiescent Current
EL7530 Datasheet
PDF, 647 Кб, Версия: 2017-10-17, Файл закачен: 9 май 2018
Купить EL7530IY-T13 на РадиоЛоцман.Цены — от 71 до 223 ₽ 10 предложений от 7 поставщиков Buck Switching Regulator IC Positive Adjustable 0.8V 1 Output 600mA 10-TFSOP, 10-MSOP (0.118, 3.00mm Width) | |||
EL7530IY-T13 Intersil | 71 ₽ | ||
EL7530IY-T13 Renesas | от 223 ₽ | ||
EL7530IY-T13 | по запросу | ||
EL7530IY-T13 Renesas | по запросу |
Корпус | 10 Ld MSOP T+R |
Индекс корпуса | M10.118A |
Пиковая температура пайки | 240°C |
# of Outputs | 1 |
Control Type | Voltage Mode |
Description | Monolithic 600mA Step-Down Regulator with Low Quiescent Current |
IOUT (max) (A) | 0.6 |
IQ | 120 µA |
Max Duty Cycle (%) | See Datasheet |
POR | No |
Peak Efficiency (%) | 94 |
SYNCH Capability | Yes |
Switching Freq. (max) | 1.5 MHz |
Switching Freq. (min) | 1.5 MHz |
Topology | Buck |
VIN (max) (V) | 5.5 |
VIN (min) (V) | 2.5 |
VOUT (max) (V) | 5.5 |
VOUT (min) (V) | 0.8 |
Серия: EL7530 (6)
- EL7530IY EL7530IY-T13 EL7530IY-T7 EL7530IYZ EL7530IYZ-T13 EL7530IYZ-T7
- Power Management > Switching Regulators > Integrated FET Regulators
EL7530IYT13, EL7530IY T13
