Datasheet Intersil EL7531IY-T7 — Даташит
Monolithic 1A Step-Down Regulator with Low Quiescent Current
EL7531 Datasheet
PDF, 693 Кб, Версия: 2017-10-18, Файл закачен: 9 май 2018
Купить EL7531IY-T7 на РадиоЛоцман.Цены — от 71 до 713 ₽ 14 предложений от 8 поставщиков Buck Switching Regulator IC Positive Adjustable 0.8V 1 Output 1A 10-TFSOP, 10-MSOP (0.118, 3.00mm Width) | |||
EL7531IY-T7 Intersil | 71 ₽ | ||
EL7531IY-T7 | от 689 ₽ | ||
EL7531IYT7 Intersil | по запросу | ||
EL7531IY-T7 | по запросу |
Корпус | 10 Ld MSOP T+R |
Индекс корпуса | M10.118A |
Пиковая температура пайки | 240°C |
# of Outputs | 1 |
BOM Total Footprint | 503.2 mm2 |
Control Type | Voltage Mode |
Description | Monolithic 1A Step-Down Regulator with Low Quiescent Current |
IOUT (max) (A) | 1 |
IQ | 120 µA |
Max Duty Cycle (%) | See Datasheet |
POR | Yes |
Peak Efficiency (%) | 94 |
SYNCH Capability | Yes |
Switching Freq. (max) | 1.4 MHz |
Switching Freq. (min) | 1.4 MHz |
Topology | Buck |
VIN (max) (V) | 5.5 |
VIN (min) (V) | 2.5 |
VOUT (max) (V) | 5.5 |
VOUT (min) (V) | 0.8 |
Серия: EL7531 (6)
- EL7531IY EL7531IY-T13 EL7531IY-T7 EL7531IYZ EL7531IYZ-T13 EL7531IYZ-T7
- Power Management > Switching Regulators > Integrated FET Regulators
EL7531IYT7, EL7531IY T7
