Datasheet Microchip ATTINY807 — Даташит
Производитель | Microchip |
Серия | ATTINY807 |
The ATtiny807 is a microcontroller using the 8-bit AVR® processor with hardware multiplier, running at up to 20MHz and 8KB Flash, 512B SRAM and 128 bytes of EEPROM in a 24-pin package
![]() 18 предложений от 9 поставщиков AVR tinyAVRTM0, Functional Safety (FuSa) Microcontroller IC 8-Bit 20MHz 8KB (8K x 8) FLASH 24-VQFN (4x4) | |||
ATTINY807-MNR Microchip | 71 ₽ | ||
ATTINY807-MNR Microchip | 72 ₽ | ||
ATTINY807-MN Microchip | от 218 ₽ | ||
ATTINY807-MF Microchip | по запросу |
ATTINY807-MFR | ATTINY807-MNR | |
N | 1 | 2 |
Корпус | VQFN | VQFN |
Parameters / Models | ATTINY807-MFR | ATTINY807-MNR |
ADC Input | 12 | 12 |
ADC with Computation | No | No |
Angular Timer | No | No |
Архитектура | 8 | 8 |
CPU Type | 8-bit AVR | 8-bit AVR |
CRC | Yes | Yes |
Class B Hardware | Yes | Yes |
Configurable Logic Cell, CLC/CCL | 1 | 1 |
Emulated EEPROM in Flash | 128 / HEF | 128 / HEF |
High Voltage Capable | No | No |
I2C | 1 | 1 |
Internal Oscillator | 20 MHz, 32 kHz | 20 MHz, 32 kHz |
Internal Voltage Reference, Bandgap | Yes | Yes |
Lead Count | 24 | 24 |
Math Accelerator | No | No |
Max 16-Bit Digital Timers | 2 | 2 |
Max ADC Resolution, Bits | 10 | 10 |
Max CPU Speed, МГц | 20 | 20 |
Количество компараторов | 1 | 1 |
Operation Voltage Max, В | 5.5 | 5.5 |
Operation Voltage Min, В | 1.8 | 1.8 |
PWM Max Resolution, Bits | 8 | 8 |
Package Width | 4x4x0.9mm | 4x4x0.9mm |
Peripheral Pin Select / Pin Muxing | Yes | Yes |
Pin count | 24 | 24 |
Размер памяти программ, KB | 8 | 8 |
SPI | 1 | 1 |
SRAM, Bytes | 512 | 512 |
Temp Range Max | 125 | 125 |
Temp Range Min | -40 | -40 |
UART | 1 | 1 |
Zero Cross detect | No | No |
Серия: ATTINY807 (2)
- Microcontrollers > 8-bit Microcontrollers
