Datasheet Microchip ATTINY806 — Даташит
Производитель | Microchip |
Серия | ATTINY806 |
The ATtiny806 is a microcontroller using the 8-bit AVR® processor with hardware multiplier, running at up to 20MHz and 8KB Flash, 512B SRAM and 128 bytes of EEPROM in 20-pin packages
Купить ATTINY806 на РадиоЛоцман.Цены — от 33 до 5 058 ₽ 15 предложений от 8 поставщиков 8 Bit MCU, AVR Family ATtiny806 Series Microcontrollers, 20 МГц, 8 КБ, 512 Байт, 20 вывод(-ов) | |||
ATTINY806-MN Microchip | 33 ₽ | ||
ATTINY806-MN Microchip | 35 ₽ | ||
ATTINY806-SF Microchip | от 189 ₽ | ||
ATTINY24A-SSUR | от 200 ₽ |
Parameters / Models | ATTINY806 |
ADC Input | 12 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit AVR |
CRC | Yes |
Class B Hardware | Yes |
Configurable Logic Cell, CLC/CCL | 1 |
Emulated EEPROM in Flash | 128 / HEF |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | 20 MHz, 32 kHz |
Internal Voltage Reference, Bandgap | Yes |
Math Accelerator | No |
Max 16-Bit Digital Timers | 2 |
Max ADC Resolution, Bits | 10 |
Max CPU Speed, МГц | 20 |
Количество компараторов | 1 |
Operation Voltage Max, В | 5.5 |
Operation Voltage Min, В | 1.8 |
PWM Max Resolution, Bits | 8 |
Pin count | 20 |
Размер памяти программ, KB | 8 |
SPI | 1 |
SRAM, Bytes | 512 |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 1 |
Zero Cross detect | No |
Серия: ATTINY806 (1)
