Datasheet Microchip ATTINY1606 — Даташит
Производитель | Microchip |
Серия | ATTINY1606 |
Модель | ATTINY1606 |
The ATtiny1606 is a microcontroller using the 8-bit AVR® processor with hardware multiplier, running at up to 20MHz and 16KB Flash, 1024B SRAM and 256 bytes of EEPROM in 20-pin packages
Купить ATTINY1606 на РадиоЛоцман.Цены — от 32 до 5 278 ₽ 16 предложений от 8 поставщиков 8 Bit MCU, AVR Family ATtiny1606 Series Microcontrollers, 20 МГц, 16 КБ, 1 КБ, 20 вывод(-ов) | |||
ATTINY1606-SN Microchip | 32 ₽ | ||
ATTINY1606-MN Microchip | 33 ₽ | ||
ATTINY1606-MNR Microchip | от 147 ₽ | ||
ATTINY1606-SN Microchip | от 194 ₽ |
ADC Input | 12 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit AVR |
CRC | Yes |
Class B Hardware | Yes |
Configurable Logic Cell | 1 CLC/CCL |
Emulated EEPROM in Flash | 256 / HEF |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | 20 MHz, 32 kHz |
Math Accelerator | No |
Max 16-Bit Digital Timers | 2 |
Max CPU Speed | 20 МГц |
Количество компараторов | 1 |
PWM Max Resolution | 8 Bits |
Pin count | 20 |
Размер памяти программ | 16 KB |
SPI | 1 |
SRAM | 1024 Bytes |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 1 |
Zero Cross detect | No |
- Microcontrollers > 8-bit Microcontrollers
