Datasheet Microchip ATTINY3216 — Даташит
Производитель | Microchip |
Серия | ATTINY3216 |
Модель | ATTINY3216 |
The ATtiny3216 microcontroller featuring the 8-bit AVR® processor with hardware multiplier - running at up to 20MHz and with up to 32 KB Flash, 2 KB SRAM and 256 bytes of EEPROM in 20-pin packages
ATtiny3216/ATtiny1616 Data Sheet
PDF, 4.8 Мб, Файл опубликован: 21 июн 2018
Купить ATTINY3216 на РадиоЛоцман.Цены — от 187 до 7 816 ₽ 13 предложений от 8 поставщиков AVR tinyAVRTM1, Functional Safety (FuSa) Microcontroller IC 8-Bit 16MHz 32KB (32K x 8) FLASH 20-SOIC | |||
ATTINY24A-SSU | от 187 ₽ | ||
ATTINY3216-SN Microchip | 202 ₽ | ||
ATTINY3216-SNR Microchip | от 226 ₽ | ||
ATTINY3216-SZT-VAO Microchip | по запросу |
ADC Input | 16 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit AVR |
CRC | Yes |
Class B Hardware | Yes |
Configurable Logic Cell | 1 CLC/CCL |
Emulated EEPROM in Flash | 256 / HEF |
Hardware Touch Peripheral | PTC |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | 20 MHz, 32 kHz |
Math Accelerator | No |
Max 16-Bit Digital Timers | 3 |
Max 8-Bit Digital Timers | 1 |
Max CPU Speed | 20 МГц |
Max DAC Resolution | 8 Bits |
Max PWM outputs | 8 including complementary |
Количество компараторов | 3 |
Number of DACs | 3 |
Pin count | 20 |
Размер памяти программ | 32 KB |
SPI | 1 |
SRAM | 2048 Bytes |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 1 |
Zero Cross detect | No |
- Microcontrollers > 8-bit Microcontrollers
