Datasheet Wago 2000-2234 — Даташит
TOPJOB S double-deck terminal block; through/through (N/N); with marker carrier; rail mount; 2-conductor; 3.5 mm wide; blue
![]() 5 предложений от 5 поставщиков 2-уровн. клемма, 0,14 - 1 (1,5) мм2, N/N, синяя | |||
2000-2234 Wago | 205 ₽ | ||
2000-2234 Wago Оф. дистрибьютор | 343 ₽ | ||
20002234 | 44 177 ₽ | ||
2000-2234 | по запросу |
Actuation type | Open Tool Slot |
Цвет | blue |
Connectable conductor materials | Copper |
Country of origin | CN |
Габариты: глубина | 69.7 mm / 2.744 inch |
Design | horizontal |
Fine-stranded conductor | 0.14 … 1.5 mm² / 24 … 16 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 0.5 mm² / 20 AWG |
Fire load | 0.162 MJ |
GTIN | 4055143267724 |
Height from upper-edge of DIN-35 rail | 61.8 mm / 2.433 inch |
Marking level | Center/side marking |
Nominal cross section | 1 mm² |
Number of connection points | 2 |
Number of connection points (connection type) | 2 |
Number of levels | 2 |
Potential marking | N/N |
Product Group | 22 (TOPJOB S) |
Rated current | 13.5 A |
Rated current (2) | 16 A |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 3) | 500 В |
Solid conductor | 0.14 … 1.5 mm² / 24 … 16 AWG |
Solid conductor, push-in termination | 0.5 … 1.5 mm² / 20 … 16 AWG |
Strip length | 9 … 11 mm / 0.35 … 0.43 Inch |
Total number of connection points | 4 |
Total number of potentials | 2 |
Type of mounting | DIN-35 rail |
Type of wiring | Front-entry wiring |
Вес | 7.66 г |
Ширина | 3.5 mm / 0.138 inch |
Серия: 2000 (100 из 161)
- 2000-1292 2000-1301 2000-1302 2000-1303 2000-1304 2000-1305 2000-1306 2000-1307 2000-1391 2000-1392 2000-1401 2000-1402 2000-1403 2000-1404 2000-1405 2000-1406 2000-1407 2000-1491 2000-1492 2000-2141 2000-2195 2000-2196 2000-2201 2000-2201/099-000 2000-2202 2000-2202/099-000 2000-2203 2000-2203/099-000 2000-2204 2000-2204/099-000 2000-2207 2000-2207/099-000 2000-2208 2000-2208/099-000 2000-2209 2000-2209/099-000 2000-2217 2000-2217/099-000 2000-2218 2000-2218/099-000 2000-2227 2000-2227/099-000 2000-2228 2000-2228/099-000 2000-2231 2000-2231/099-000 2000-2232 2000-2232/099-000 2000-2233 2000-2233/099-000 2000-2234 2000-2234/099-000 2000-2237 2000-2237/099-000 2000-2238 2000-2238/099-000 2000-2239 2000-2239/099-000 2000-2247 2000-2247/099-000 2000-2248 2000-2248/099-000 2000-2257 2000-2257/099-000 2000-2258 2000-2258/099-000 2000-2291 2000-2292 2000-402 2000-402/000-005 2000-402/000-006 2000-402/000-018 2000-403 2000-403/000-005 2000-403/000-006 2000-404 2000-404/000-005 2000-404/000-006 2000-405 2000-405/000-005 2000-405/000-006 2000-405/011-000 2000-406 2000-406/000-005 2000-406/000-006 2000-406/020-000 2000-407 2000-407/000-005 2000-407/000-006 2000-408 2000-408/000-005 2000-408/000-006 2000-409 2000-409/000-005 2000-409/000-006 2000-410 2000-410/000-005 2000-410/000-006 2000-433 2000-433/000-005
20002234, 2000 2234
