Datasheet Wago 2003-6646 — Даташит
Multilevel installation terminal block; N/L/PE
Купить 2003-6646 на РадиоЛоцман.Цены — от 114 до 933 ₽ Многоуровневая Клемма, 0,25 - 2,5 (4) мм2, N/L/PE | |||
2003-6646 Wago | 114 ₽ | ||
2003-6646 Wago Оф. дистрибьютор | 559 ₽ | ||
2003-6646 Wago | 933 ₽ | ||
2003-6646 Wago | по запросу |
Actuation type | Open Tool Slot |
Цвет | gray |
Connectable conductor materials | Copper |
Country of origin | CN |
Габариты: глубина | 110 mm / 4.331 inch |
Design | angled |
Fine-stranded conductor | 0.25 … 4 mm² / 22 … 12 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 0.75 mm² / 18 AWG |
Fire load | 0.308 MJ |
GTIN | 4050821322061 |
Height from upper-edge of DIN-35 rail | 44.3 mm / 1.744 inch |
Marking level | Center/side marking |
Nominal cross section | 2.5 mm² |
Number of levels | 3 |
Potential marking | N/L/PE |
Product Group | 22 (TOPJOB S) |
Rated current | 24 A |
Rated impulse voltage (III / 3) 2 | 6 kV |
Rated voltage (III / 3) | 250 В |
Rated voltage (III / 3) 2 | 400 В |
Ratings note | potential - ground |
Ratings note 2 | potential-potential |
Solid conductor | 0.25 … 4 mm² / 22 … 12 AWG |
Solid conductor, push-in termination | 0.75 … 4 mm² / 18 … 12 AWG |
Strip length | 10 … 12 mm / 0.39 … 0.47 Inch |
Total number of connection points | 5 |
Total number of potentials | 3 |
Type of mounting | DIN-35 rail |
Type of wiring | Front-entry wiring |
Вес | 20.052 г |
Ширина | 5.2 mm / 0.205 inch |
Серия: 2003 (29)
20036646, 2003 6646
