Datasheet Wago 2002-2257 — Даташит
Серия2002
Модель2002-2257
TOPJOB S double-deck terminal block; ground/through (PE/L); with marker carrier; rail mount; 2-conductor; 5.2 mm wide; gray
2-уровневая клемма, 2,5 (4) мм2, PE / L держ. марк., серая
Industrial Module
112 ₽
2002-2257
Оф. дистрибьютор
641 ₽
Критерии выбора литиевых аккумуляторов и батареек: что необходимо учитывать разработчикам
Actuation typeOpen Tool Slot
Цветgray
Country of originDE
Габариты: глубина69.7 mm / 2.744 inch
Designhorizontal
Fine-stranded conductor0.25 … 4 mm² / 22 … 12 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 18 AWG
Fire load0.212 MJ
GTIN4044918989787
Height from upper-edge of DIN-35 rail61.8 mm / 2.433 inch
Marking levelCenter/side marking
Nominal cross section2.5 mm²
Number of connection points2
Number of connection points (connection type)2
Number of levels2
Potential markingPE/L
Product Group22 (TOPJOB S)
Rated current (Ex e II)20 A
Rated current (Ex e II) with jumper18 A
Rated voltage EN (Ex e II)440 В
Solid conductor0.25 … 4 mm² / 22 … 12 AWG
Solid conductor, push-in termination0.75 … 4 mm² / 18 … 12 AWG
Strip length10 … 12 mm / 0.39 … 0.47 Inch
Total number of connection points4
Total number of potentials2
Type of mountingDIN-35 rail
Вес13.34 г
Ширина5.2 mm / 0.205 inch
20022257, 2002 2257
На английском языке: Datasheet Wago 2002-2257
