Datasheet Wago 2002-2971 — Даташит
Double-deck disconnect terminal block; knife disconnect; through/through (L/L); rail mount; 2-conductor; 5.2 mm wide; gray
Купить 2002-2971 на РадиоЛоцман.Цены — от 1 564 до 5 165 ₽ 5 предложений от 5 поставщиков 2-уровневая клемма с размыкателями, 2,5 (4) мм2 | |||
2002-2971 Wago Оф. дистрибьютор | 1 564 ₽ | ||
2002-2971 Wago | 273 ₽ | ||
2002-2971 Wago | 535 ₽ | ||
2002-2971 Wago | 546 ₽ |
Actuation type | Open Tool Slot |
Цвет | gray |
Connectable conductor materials | Copper |
Country of origin | CN |
Габариты: глубина | 108 mm / 4.252 inch |
Design | horizontal |
Fine-stranded conductor | 0.25 … 4 mm² / 22 … 12 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 0.75 mm² / 18 AWG |
Fire load | 0.292 MJ |
GTIN | 4050821006817 |
Height from upper-edge of DIN-35 rail | 42 mm / 1.654 inch |
Marking level | Side marking |
Nominal cross section | 2.5 mm² |
Number of levels | 2 |
Potential marking | L/L |
Product Group | 22 (TOPJOB S) |
Rated current | 16 A |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 3) | 400 В |
Solid conductor | 0.25 … 4 mm² / 22 … 12 AWG |
Solid conductor, push-in termination | 0.75 … 4 mm² / 18 … 12 AWG |
Strip length | 10 … 12 mm / 0.39 … 0.47 Inch |
Total number of connection points | 4 |
Total number of potentials | 4 |
Type of mounting | DIN-35 rail |
Type of wiring | Front-entry wiring |
Вес | 17.351 г |
Ширина | 5.2 mm / 0.205 inch |
Серия: 2002 (100 из 422)
- 2002-2438 2002-2439 2002-2447 2002-2448 2002-2457 2002-2458 2002-2491 2002-2492 2002-2601 2002-2602 2002-2603 2002-2604 2002-2607 2002-2608 2002-2609 2002-2611 2002-2611/1000-541 2002-2611/1000-542 2002-2611/1000-836 2002-2611/1000-867 2002-2612 2002-2647 2002-2657 2002-2661 2002-2662 2002-2667 2002-2671 2002-2672 2002-2678 2002-2691 2002-2692 2002-2701 2002-2702 2002-2703 2002-2704 2002-2707 2002-2708 2002-2709 2002-2717 2002-2727 2002-2791 2002-2792 2002-2941 2002-2951 2002-2952 2002-2954 2002-2958 2002-2959 2002-2961 2002-2963 2002-2971 2002-2972 2002-2974 2002-2991 2002-2992 2002-3201 2002-3203 2002-3204 2002-3207 2002-3208 2002-3209 2002-3211/1000-410 2002-3211/1000-411 2002-3211/1000-675 2002-3211/1000-676 2002-3212/1000-673 2002-3212/1000-674 2002-3217 2002-3218 2002-3221/1000-413 2002-3221/1000-434 2002-3227 2002-3228 2002-3231 2002-3233 2002-3234 2002-3237 2002-3238 2002-3239 2002-3247 2002-3248 2002-3257 2002-3258 2002-3291 2002-3292 2002-400 2002-401 2002-402 2002-402/000-005 2002-402/000-006 2002-403 2002-403/000-005 2002-403/000-006 2002-404 2002-404/000-005 2002-404/000-006 2002-405 2002-405/000-005 2002-405/000-006 2002-405/011-000
20022971, 2002 2971
