Datasheet Wago 2002-1981/1000-434 — Даташит
TOPJOB S fuse terminal block; mini-auto fuse; with blown fuse LED indication for 24 V (P-N); with additional jumper location; rail mount; 2-conductor; 5.2 mm wide; gray
Купить 2002-1981/1000-434 на РадиоЛоцман.Цены — от 391 до 2 344 ₽ 2-пр. держ. предохранителя, вилочн. (автомоб), индикатор | |||
2002-1981/1000-434 Wago | 391 ₽ | ||
2002-1981/1000-434 Wago Оф. дистрибьютор | 1 222 ₽ | ||
2002-1981/1000-434 Wago | 2 344 ₽ | ||
2002-1981/1000-434 Wago | по запросу |
Actuation type | Open Tool Slot |
Цвет | gray |
Connectable conductor materials | Copper |
Country of origin | DE |
Габариты: глубина | 72.9 mm / 2.87 inch |
Design | horizontal |
Fine-stranded conductor | 0.25 … 4 mm² / 22 … 12 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 0.75 mm² / 18 AWG |
GTIN | 4050821127055 |
Height from upper-edge of DIN-35 rail | 32.9 mm / 1.295 inch |
Marking level | Center/side marking |
Nominal cross section | 2.5 mm² |
Number of levels | 1 |
Product Group | 22 (TOPJOB S) |
Rated current | 10 A |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 3) | 400 В |
Solid conductor | 0.25 … 4 mm² / 22 … 12 AWG |
Solid conductor, push-in termination | 0.75 … 4 mm² / 18 … 12 AWG |
Strip length | 10 … 12 mm / 0.39 … 0.47 Inch |
Total number of connection points | 2 |
Total number of potentials | 2 |
Type of mounting | DIN-35 rail |
Type of wiring | Front-entry wiring |
Вес | 8.2 г |
Ширина | 5.2 mm / 0.205 inch |
Серия: 2002 (100 из 422)
- 2002-1771 2002-1771/401-000 2002-1772 2002-1772/401-000 2002-1774 2002-1774/401-000 2002-1781 2002-1791 2002-1792 2002-1801 2002-1802 2002-1804 2002-1811 2002-1811/1000-541 2002-1811/1000-542 2002-1811/1000-836 2002-1811/1000-867 2002-1861 2002-1871 2002-1871/401-000 2002-1872 2002-1872/401-000 2002-1874 2002-1874/401-000 2002-1881 2002-1891 2002-1892 2002-1901 2002-1902 2002-1904 2002-1907 2002-191 2002-1911 2002-1911/1000-541 2002-1911/1000-542 2002-1911/1000-836 2002-1911/1000-867 2002-192 2002-194 2002-1961 2002-1971 2002-1971/401-000 2002-1972 2002-1972/401-000 2002-1974 2002-1974/401-000 2002-1981 2002-1981/1000-413 2002-1981/1000-414 2002-1981/1000-429 2002-1981/1000-434 2002-1981/1000-435 2002-1981/1000-449 2002-1991 2002-1992 2002-2201 2002-2201/097-000 2002-2201/098-000 2002-2201/099-000 2002-2202 2002-2202/099-000 2002-2203 2002-2203/099-000 2002-2204 2002-2204/099-000 2002-2207 2002-2207/099-000 2002-2208 2002-2208/099-000 2002-2209 2002-2209/099-000 2002-2211/1000-410 2002-2211/1000-411 2002-2213/1000-487 2002-2213/1000-488 2002-2214/1000-490 2002-2214/1000-491 2002-2214/1000-492 2002-2217 2002-2217/099-000 2002-2218 2002-2218/099-000 2002-2221/1000-413 2002-2221/1000-434 2002-2227 2002-2227/099-000 2002-2228 2002-2228/099-000 2002-2231 2002-2231/099-000 2002-2232 2002-2232/099-000 2002-2233 2002-2233/099-000 2002-2234 2002-2234/099-000 2002-2237 2002-2237/099-000 2002-2238 2002-2238/099-000
20021981/1000434, 2002 1981/1000 434
