Datasheet Wago 2002-1707 — Даташит
Серия2002
Модель2002-1707
TOPJOB S ground terminal block; same profile as other 2002-17xx terminal blocks; rail mount; 3-conductor; 5.2 mm wide; green-yellow
3-пров. проходная клемма, 0,25 - 2,5 (4) мм2, with test option same profile as 3-conductor disconne, green-yellow
Industrial Module
157 ₽
2002-1707
Оф. дистрибьютор
852 ₽
Электромеханические реле Hongfa – надежность и качество 19 января 2023
Actuation typeOpen Tool Slot
Цветgreen-yellow
Country of originDE
Габариты: глубина76.8 mm / 3.024 inch
Designhorizontal
Fine-stranded conductor0.25 … 4 mm² / 22 … 12 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 18 AWG
Fire load0.172 MJ
GTIN4050821707516
Height from upper-edge of DIN-35 rail32.9 mm / 1.295 inch
Marking levelCenter/side marking
Nominal cross section2.5 mm²
Number of levels1
Product Group22 (TOPJOB S)
Solid conductor0.25 … 4 mm² / 22 … 12 AWG
Solid conductor, push-in termination0.75 … 4 mm² / 18 … 12 AWG
Strip length10 … 12 mm / 0.39 … 0.47 Inch
Total number of connection points3
Total number of potentials1
Type of mountingDIN-35 rail
Вес11.511 г
Ширина5.2 mm / 0.205 inch
20021707, 2002 1707
На английском языке: Datasheet Wago 2002-1707
