Datasheet Wago 2000-5352 — Даташит
TOPJOB S sensor supply terminal block; 2-pole; rail mount; 3-conductor; 7 mm wide; orange
Купить 2000-5352 на РадиоЛоцман.Цены — от 969 до 132 530 ₽ 5 предложений от 5 поставщиков 3-conductor sensor supply terminal block Power supply from control panel side, orange (15 шт) | |||
2000-5352 Wago | 969 ₽ | ||
2000-5352 Wago | 2 429 ₽ | ||
2000-5352 Wago | 54 ₽ | ||
20005352 | 132 530 ₽ |
Actuation type | Open Tool Slot |
Цвет | orange |
Connectable conductor materials | Copper |
Country of origin | DE |
Design | horizontal |
Fine-stranded conductor | 0.14 … 1.5 mm² / 24 … 16 AWG |
Fine-stranded conductor (2) | 0.25 … 4 mm² / 22 … 12 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 0.5 mm² / 20 AWG |
GTIN | 4055143497121 |
Height from upper-edge of DIN-35 rail | 49.4 mm / 1.945 inch |
Marking level | Center/side marking |
Nominal cross section | 1 mm² |
Rated current | 28 A |
Rated voltage (III / 3) | 250 В |
Solid conductor | 0.14 … 1.5 mm² / 24 … 16 AWG |
Solid conductor (2) | 0.25 … 4 mm² / 22 … 12 AWG |
Solid conductor, push-in termination | 0.5 … 1.5 mm² / 20 … 16 AWG |
Solid conductor, push-in termination (2) | 0.25 … 4 mm² / 22 … 12 AWG |
Strip length | 9 … 11 mm / 0.35 … 0.43 Inch |
Total number of connection points | 8 |
Total number of potentials | 2 |
Type of mounting | DIN-35 rail |
Type of wiring | Front-entry wiring |
Вес | 15.856 г |
Ширина | 7 mm / 0.276 inch |
Серия: 2000 (100 из 161)
- 2000-2237 2000-2237/099-000 2000-2238 2000-2238/099-000 2000-2239 2000-2239/099-000 2000-2247 2000-2247/099-000 2000-2248 2000-2248/099-000 2000-2257 2000-2257/099-000 2000-2258 2000-2258/099-000 2000-2291 2000-2292 2000-402 2000-402/000-005 2000-402/000-006 2000-402/000-018 2000-403 2000-403/000-005 2000-403/000-006 2000-404 2000-404/000-005 2000-404/000-006 2000-405 2000-405/000-005 2000-405/000-006 2000-405/011-000 2000-406 2000-406/000-005 2000-406/000-006 2000-406/020-000 2000-407 2000-407/000-005 2000-407/000-006 2000-408 2000-408/000-005 2000-408/000-006 2000-409 2000-409/000-005 2000-409/000-006 2000-410 2000-410/000-005 2000-410/000-006 2000-433 2000-433/000-005 2000-433/000-006 2000-434 2000-435 2000-436 2000-437 2000-438 2000-439 2000-440 2000-492 2000-510 2000-511 2000-5310/101-000 2000-5310/102-000 2000-5310/1101-951 2000-5310/1102-950 2000-5311 2000-5311/1101-951 2000-5311/1102-950 2000-5317/101-000 2000-5317/102-000 2000-5317/1101-951 2000-5317/1102-950 2000-5352 2000-5352/1102-953 2000-5357/101-000 2000-5357/102-000 2000-5372 2000-5372/1102-953 2000-5377/101-000 2000-5377/102-000 2000-5391 2000-5410 2000-5410/1101-951 2000-5410/1102-950 2000-5417 2000-5417/1101-951 2000-5417/1102-950 2000-5457 2000-5457/1102-953 2000-5477 2000-5477/1102-953 2000-549 2000-5491 2000-552 2000-553 2000-554 2000-555 2000-556 2000-557 2000-558 2000-559 2000-560
20005352, 2000 5352
