Datasheet Wago 2002-2403 — Даташит
TOPJOB S double-deck terminal block; through/through (L/N); rail mount; 4-conductor; 5.2 mm wide; gray
Купить 2002-2403 на РадиоЛоцман.Цены — от 267 до 101 615 ₽ 5 предложений от 5 поставщиков 2-уровн. клемма, 0,25 - 2,5 (4) мм2, 4-пров., серая, L/N | |||
2002-2403 Wago | 267 ₽ | ||
2002-2403 Wago Оф. дистрибьютор | 485 ₽ | ||
2002-2403 Wago | 3 078 ₽ | ||
20022403 | 101 615 ₽ |
Actuation type | Open Tool Slot |
Цвет | gray |
Connectable conductor materials | Copper |
Country of origin | CN |
Габариты: глубина | 105.1 mm / 4.138 inch |
Design | horizontal |
Fine-stranded conductor | 0.25 … 4 mm² / 22 … 12 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 0.75 mm² / 18 AWG |
Fire load | 0.294 MJ |
GTIN | 4050821144984 |
Height from upper-edge of DIN-35 rail | 52.1 mm / 2.051 inch |
Marking level | Center/side marking |
Nominal cross section | 2.5 mm² |
Number of connection points | 4 |
Number of connection points (connection type) | 4 |
Number of levels | 2 |
Potential marking | L/N |
Product Group | 22 (TOPJOB S) |
Rated current | 24 A |
Rated current (2) | 28 A |
Rated impulse voltage (III / 3) | 8 kV |
Rated voltage (III / 3) | 800 В |
Solid conductor | 0.25 … 4 mm² / 22 … 12 AWG |
Solid conductor, push-in termination | 0.75 … 4 mm² / 18 … 12 AWG |
Strip length | 10 … 12 mm / 0.39 … 0.47 Inch |
Total number of connection points | 8 |
Total number of potentials | 2 |
Type of mounting | DIN-35 rail |
Type of wiring | Front-entry wiring |
Вес | 15.759 г |
Ширина | 5.2 mm / 0.205 inch |
Серия: 2002 (100 из 422)
- 2002-2207/099-000 2002-2208 2002-2208/099-000 2002-2209 2002-2209/099-000 2002-2211/1000-410 2002-2211/1000-411 2002-2213/1000-487 2002-2213/1000-488 2002-2214/1000-490 2002-2214/1000-491 2002-2214/1000-492 2002-2217 2002-2217/099-000 2002-2218 2002-2218/099-000 2002-2221/1000-413 2002-2221/1000-434 2002-2227 2002-2227/099-000 2002-2228 2002-2228/099-000 2002-2231 2002-2231/099-000 2002-2232 2002-2232/099-000 2002-2233 2002-2233/099-000 2002-2234 2002-2234/099-000 2002-2237 2002-2237/099-000 2002-2238 2002-2238/099-000 2002-2239 2002-2239/099-000 2002-2247 2002-2247/099-000 2002-2248 2002-2248/099-000 2002-2257 2002-2257/099-000 2002-2258 2002-2258/099-000 2002-2291 2002-2292 2002-2295 2002-2296 2002-2401 2002-2402 2002-2403 2002-2404 2002-2407 2002-2408 2002-2409 2002-2417 2002-2418 2002-2427 2002-2428 2002-2431 2002-2432 2002-2433 2002-2434 2002-2437 2002-2438 2002-2439 2002-2447 2002-2448 2002-2457 2002-2458 2002-2491 2002-2492 2002-2601 2002-2602 2002-2603 2002-2604 2002-2607 2002-2608 2002-2609 2002-2611 2002-2611/1000-541 2002-2611/1000-542 2002-2611/1000-836 2002-2611/1000-867 2002-2612 2002-2647 2002-2657 2002-2661 2002-2662 2002-2667 2002-2671 2002-2672 2002-2678 2002-2691 2002-2692 2002-2701 2002-2702 2002-2703 2002-2704 2002-2707
20022403, 2002 2403
