Datasheet Wago 2002-1711/1000-836 — Даташит
TOPJOB S fuse disconnect terminal block; with pivoting fuse holder for 5 x 20 mm fuse; with blown fuse LED indication for 230 V; rail mount; 3-conductor; 6.2 mm wide; gray
Купить 2002-1711/1000-836 на РадиоЛоцман.Цены — от 410 до 1 690 ₽ 3-пр. держ. предохранителя, 5x20 мм, 0,25 - 2,5 (4) мм2, инд. 110-250 В | |||
2002-1711/1000-836 Wago | 410 ₽ | ||
2002-1711/1000-836 Wago Оф. дистрибьютор | 1 690 ₽ | ||
2002-1711/1000-836 Wago | по запросу |
Actuation type | Open Tool Slot |
Цвет | gray |
Connectable conductor materials | Copper |
Country of origin | DE |
Габариты: глубина | 76.8 mm / 3.024 inch |
Design | horizontal |
Fine-stranded conductor | 0.25 … 4 mm² / 22 … 12 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 0.75 mm² / 18 AWG |
GTIN | 4050821707639 |
Height from upper-edge of DIN-35 rail | 57.6 mm / 2.268 inch |
Marking level | Center/side marking |
Nominal cross section | 2.5 mm² |
Number of levels | 1 |
Rated current | 6.3 A |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 3) | 250 В |
Solid conductor | 0.25 … 4 mm² / 22 … 12 AWG |
Solid conductor, push-in termination | 0.75 … 4 mm² / 18 … 12 AWG |
Strip length | 10 … 12 mm / 0.39 … 0.47 Inch |
Total number of connection points | 3 |
Total number of potentials | 1 |
Type of mounting | DIN-35 rail |
Type of wiring | Front-entry wiring |
Вес | 15.036 г |
Ширина | 6.2 mm / 0.244 inch |
Серия: 2002 (100 из 422)
- 2002-1401 2002-1402 2002-1403 2002-1404 2002-1405 2002-1406 2002-1407 2002-1408 2002-1411/1000-410 2002-1411/1000-411 2002-1421/1000-413 2002-1421/1000-434 2002-1441 2002-1491 2002-1492 2002-1493 2002-1494 2002-1549 2002-1568 2002-1591 2002-1592 2002-1593 2002-1594 2002-1601 2002-1602 2002-1604 2002-1611 2002-1611/1000-541 2002-1611/1000-542 2002-1611/1000-836 2002-1611/1000-867 2002-1661 2002-1662 2002-1671 2002-1671/401-000 2002-1672 2002-1672/401-000 2002-1674 2002-1674/401-000 2002-1681 2002-1691 2002-1692 2002-1701 2002-1702 2002-1704 2002-1707 2002-171 2002-1711 2002-1711/1000-541 2002-1711/1000-542 2002-1711/1000-836 2002-1711/1000-867 2002-172 2002-1761 2002-1771 2002-1771/401-000 2002-1772 2002-1772/401-000 2002-1774 2002-1774/401-000 2002-1781 2002-1791 2002-1792 2002-1801 2002-1802 2002-1804 2002-1811 2002-1811/1000-541 2002-1811/1000-542 2002-1811/1000-836 2002-1811/1000-867 2002-1861 2002-1871 2002-1871/401-000 2002-1872 2002-1872/401-000 2002-1874 2002-1874/401-000 2002-1881 2002-1891 2002-1892 2002-1901 2002-1902 2002-1904 2002-1907 2002-191 2002-1911 2002-1911/1000-541 2002-1911/1000-542 2002-1911/1000-836 2002-1911/1000-867 2002-192 2002-194 2002-1961 2002-1971 2002-1971/401-000 2002-1972 2002-1972/401-000 2002-1974 2002-1974/401-000
20021711/1000836, 2002 1711/1000 836
