Datasheet Wago 2002-1804 — Даташит
Серия2002
Модель2002-1804
TOPJOB S feedthrough terminal block; same profile as other 2002-18xx terminal blocks; rail mount; 4-conductor; 5.2 mm wide; blue
4-пров. проходная клемма, 0,25 - 2,5 (4) мм2, with test option same profile as 4-conductor disconnect t, blue
2002-1804
Оф. дистрибьютор
538 ₽
Industrial Module
95 ₽
Actuation typeOpen Tool Slot
Цветblue
Country of originCN
Габариты: глубина87.5 mm / 3.445 inch
Designhorizontal
Fine-stranded conductor0.25 … 4 mm² / 22 … 12 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 18 AWG
Fire load0.191 MJ
GTIN4045454974701
Height from upper-edge of DIN-35 rail32.9 mm / 1.295 inch
Marking levelCenter/side marking
Nominal cross section2.5 mm²
Number of levels1
Rated current16 A
Rated voltage (III / 3)400 В
Solid conductor0.25 … 4 mm² / 22 … 12 AWG
Solid conductor, push-in termination0.75 … 4 mm² / 18 … 12 AWG
Strip length10 … 12 mm / 0.39 … 0.47 Inch
Total number of connection points4
Total number of potentials1
Type of mountingDIN-35 rail
Вес9.823 г
Ширина5.2 mm / 0.205 inch
20021804, 2002 1804
На английском языке: Datasheet Wago 2002-1804
