Datasheet Texas Instruments PTMP117AIDRVR — Даташит
Серия | TMP117 |
Модель | PTMP117AIDRVR |
±0.1°C Accurate Digital Temperature Sensor with Integrated NV Memory 6-WSON -55 to 150
TMP117x High-Accuracy, Low-Power, Digital Temperature Sensor With SMBus- and I2C-Compatible Interface datasheet
PDF, 1.3 Мб, Файл опубликован: 29 июн 2018
Pin | 6 |
Package Type | DRV |
Industry STD Term | WSON |
JEDEC Code | S-PDSO-N |
Package QTY | 3000 |
Carrier | LARGE T&R |
Width (мм) | 2 |
Length (мм) | 2 |
Thickness (мм) | 0.75 |
Pitch (мм) | 0.65 |
Max Height (мм) | 0.8 |
Mechanical Data | Скачать |
Addresses | 4 |
Device Type | Local |
Основные особенности | Programmable Alert,One-Shot Conversion,15ms Conversion Time,EEPROM,250nA Shutdown Current,Programmable Conversion Cycle Averaging Mode,NIST Traceable |
Interface | I2C, SMBus, 2-Wire |
Local Sensor Accuracy(Max) | 0.1 +/- C |
Рабочий диапазон температур | от -55 до 150,0 до 85 C |
Package Group | WSON|6 |
Package Size: mm2:W x L | See datasheet (WSON) PKG |
Rating | Catalog |
Supply Current(Max) | 4.5 uA |
Supply Current(Typ) | 3.5 uA |
Supply Voltage(Max) | 5.5 В |
Supply Voltage(Min) | 1.8 В |
Temp Resolution(Max) | 16 bits |
RoHS | See ti.com |
- Evaluation Modules & Boards: TMP117EVM
TMP117 Digital Temperature Sensor Evaluation Board
- Layout Considerations for Wearable Temperature SensingPDF, 335 Кб, Файл опубликован: 26 июл 2018
- Design Challenges of Wearable Temperature SensingPDF, 340 Кб, Файл опубликован: 14 сен 2018
- RTD Replacement in Heat Meter & Cold Junction Compensation Systems (Rev. B)PDF, 176 Кб, Версия: B, Файл опубликован: 18 окт 2018
- Design Considerations for Measuring Ambient Air Temperature (Rev. B)PDF, 1.4 Мб, Версия: B, Файл опубликован: 10 сен 2018
Power-hungryelectroniccomponentssuchas processorchipsfield programmablegatearrays(FPGAs)application-specificintegratedcircuits(ASICs)as well as powerICs heatup duringoperation.Whenthesystemis turnedon the heatgeneratedby theseICs transfersto lowertemperatureobjectsnearby.Measuringambientair temperaturewith a surfacemountdevi - Replacing Resistance Temperature Detectors with the TMP116 Temp SensorPDF, 133 Кб, Файл опубликован: 6 ноя 2017
- Ambient Temperature Measurement Layout ConsiderationsPDF, 893 Кб, Файл опубликован: 16 июл 2018
- Calculating Useful Lifetimes of Temperature SensorsPDF, 522 Кб, Файл опубликован: 6 июл 2018
- Temperature sensors: PCB guidelines for surface mount devices (Rev. A)PDF, 5.6 Мб, Версия: A, Файл опубликован: 18 янв 2019
Power hungry electronic components such as CPUs GPUs or FPGAs as well as voltage regulators heat up during operation. Some applications require ambient air temperature measurements while others need to measure the temperature of a nearby component on the PCB. Measuring ambient air temperature with a surface mount technology (SMT) device is challenging due to the thermal influence of other compo
Серия: TMP117 (7)
- PTMP117AIDRVR TMP117AIDRVR TMP117AIDRVT TMP117MAIDRVR TMP117MAIDRVT TMP117NAIDRVR TMP117NAIDRVT
- Semiconductors > Analog and Mixed-Signal > Sensors > Temperature sensors > Digital temperature sensors
