Datasheet Wago 2002-1811/1000-867 — Даташит
TOPJOB S fuse disconnect terminal block; with pivoting fuse holder for 5 x 20 mm fuse; with blown fuse LED indication for 120 V; rail mount; 4-conductor; 6.2 mm wide; gray
Купить 2002-1811/1000-867 на РадиоЛоцман.Цены — от 520 до 3 398 ₽ 4-пр. держ. предохранителя, 5x20 мм, 0,25 - 2,5 (4) мм2, инд. 120 В | |||
2002-1811/1000-867 Wago | 520 ₽ | ||
2002-1811/1000-867 Wago Оф. дистрибьютор | 1 954 ₽ | ||
2002-1811/1000-867 Wago | 3 398 ₽ | ||
2002-1811/1000-867 Wago | по запросу |
Actuation type | Open Tool Slot |
Цвет | gray |
Connectable conductor materials | Copper |
Country of origin | DE |
Габариты: глубина | 87.5 mm / 3.445 inch |
Design | horizontal |
Fine-stranded conductor | 0.25 … 4 mm² / 22 … 12 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 0.75 mm² / 18 AWG |
GTIN | 4050821214236 |
Height from upper-edge of DIN-35 rail | 57.2 mm / 2.252 inch |
Marking level | Center/side marking |
Nominal cross section | 2.5 mm² |
Number of levels | 1 |
Product Group | 22 (TOPJOB S) |
Rated current | 6.3 A |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 3) | 250 В |
Solid conductor | 0.25 … 4 mm² / 22 … 12 AWG |
Solid conductor, push-in termination | 0.75 … 4 mm² / 18 … 12 AWG |
Strip length | 10 … 12 mm / 0.39 … 0.47 Inch |
Total number of connection points | 4 |
Total number of potentials | 1 |
Type of mounting | DIN-35 rail |
Type of wiring | Front-entry wiring |
Вес | 16.685 г |
Ширина | 6.2 mm / 0.244 inch |
Серия: 2002 (100 из 422)
- 2002-1592 2002-1593 2002-1594 2002-1601 2002-1602 2002-1604 2002-1611 2002-1611/1000-541 2002-1611/1000-542 2002-1611/1000-836 2002-1611/1000-867 2002-1661 2002-1662 2002-1671 2002-1671/401-000 2002-1672 2002-1672/401-000 2002-1674 2002-1674/401-000 2002-1681 2002-1691 2002-1692 2002-1701 2002-1702 2002-1704 2002-1707 2002-171 2002-1711 2002-1711/1000-541 2002-1711/1000-542 2002-1711/1000-836 2002-1711/1000-867 2002-172 2002-1761 2002-1771 2002-1771/401-000 2002-1772 2002-1772/401-000 2002-1774 2002-1774/401-000 2002-1781 2002-1791 2002-1792 2002-1801 2002-1802 2002-1804 2002-1811 2002-1811/1000-541 2002-1811/1000-542 2002-1811/1000-836 2002-1811/1000-867 2002-1861 2002-1871 2002-1871/401-000 2002-1872 2002-1872/401-000 2002-1874 2002-1874/401-000 2002-1881 2002-1891 2002-1892 2002-1901 2002-1902 2002-1904 2002-1907 2002-191 2002-1911 2002-1911/1000-541 2002-1911/1000-542 2002-1911/1000-836 2002-1911/1000-867 2002-192 2002-194 2002-1961 2002-1971 2002-1971/401-000 2002-1972 2002-1972/401-000 2002-1974 2002-1974/401-000 2002-1981 2002-1981/1000-413 2002-1981/1000-414 2002-1981/1000-429 2002-1981/1000-434 2002-1981/1000-435 2002-1981/1000-449 2002-1991 2002-1992 2002-2201 2002-2201/097-000 2002-2201/098-000 2002-2201/099-000 2002-2202 2002-2202/099-000 2002-2203 2002-2203/099-000 2002-2204 2002-2204/099-000 2002-2207
20021811/1000867, 2002 1811/1000 867
